1972 CHEVY CHEVELLE - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2001, 05:51 PM
Post 1972 CHEVY CHEVELLE
I HAVE P275 60X15 TIRES ON MY CAR I HAVE CHANGED THE SPEEDOMETER CABLE AND THE SPEEDOMETER AND IT IS STILL WAY OFF.WHEN I AM DOING 40MPH I HAVE BEEN CLOCKED AT 70 MPH. DID MY TIRES CHANGE THE SPEED AND IF SO WHAT CAN BE DONE
Old 09-05-2001, 12:20 PM
Post
Change the speedo gear in the trans, get the gear at your GM dealer. Give them the rear axel gear ratio, and the rear tire diameter. They should hook you up.
Old 10-07-2001, 04:00 AM
Post
Food for thought - adding larger dia. tires has changed your gear ratio - unless your motor is bone stock big block I would expect your car is a dog off the line now. You can adapt your speedo gear to read the correct speed however if it were my car I'd want to match the gear ratio with the tire dia. I wanted to run. The taller the tire - the taller gear you'll need. Any rear end shop can tell you the correct ratio if you provide your desired cruise RPM & tire dia.
I use a 4:56 for 33" 4:10 for 30" tires & 3:70 for 29" or less.
