1972 chevy k20
ok heres my situation. i have the oringinal wiring harness in my 72 chevy truck. but its shot. and i cant afford a new one. and i need taillights and fuel gauge. can someone please tell me or show me how to hook all this up. thank you.
On my '75 the tail-light wiring runs from the fuse-box area in the engine compartment, down the driver's side frame rail to the tail-lights. The wiring colors are standard for GM (white, brown, green and yellow), and you can use replacement wiring that is used for trailers. Most auto parts stores carry the color-coded wiring.
The gas tank is grounded - so first make sure the ground wire is still there. There must also be a sending unit wire power that runs from the sending unit to the dash gauge, and then through the ignition switch to 12 volts. On my truck the sending unit wire is tan, but I don't know about your '72. Bruce |
72 electrical problems
so which wire going to my fuel gauge is 12 volts. and what do i need to do to hook my fuel gauge back up. i dont wanna run any of my other gauges. just my one fuel gauge. thank you. because theres a short somewhere...
Is there power to the instrument panel, or is something grounded or shorted so you can't use the stock panel? If you can't get the panel to work, it might be easier to add an external fuel gauge.
The instrument panel should have a main ground wire (black), and if its disconnected you will have problems with all kinds of things. You also need 12 volts from the fuse box to the instruments, and there should be a separate fuse for that circuit. Power will be switched on and off through the ignition switch. Bruce |
fuel gauge and wiring.
i gutted everything. cant i just run 12 volts to the switch or something. im looking to do something simple. thank you
Locate the sending unit on the gas tank first. Find the sending unit wire (the other wire will be ground) and trace it back toward the instrument cluster.
Buy an add-on fuel gauge that uses a 0-90 ohm sender (very common) and install it under the dash. Connect 12 volts switched to one side of the gauge, and the sending unit wire to the other side. The gauge should now work. Bruce |
| List all of your cars HERE! | Carbed95GT | Hotrodders' Lounge | 289 | 11-09-2011 06:43 PM |
| Hi. just wondering why the 350 chevy small block is so good... | judgedredd | Hotrodders' Lounge | 78 | 06-25-2010 08:01 AM |
| 1972' Chevy truck full restoration | J3Jon | Suspension - Brakes - Steering | 1 | 04-20-2007 09:09 PM |
| 1972 Chevy C10 | MyMalibu | Hotrodding Basics | 27 | 10-27-2006 06:16 AM |
| 1972 CHEVY CHEVELLE | FINALLY | Transmission - Rearend | 2 | 10-07-2001 04:00 AM |
