1972' Chevy truck full restoration - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2007, 08:49 PM
I want to a chassis swap because my truck is a long horn and my other junk one is a longbed,The frame is good and in decent shape.I have an early classic kit the 4/6" drop kit,I want to lower it and replace everything for the suspension,I also bought a painless wiring kit,I dont really know much about installing them but nothing has ever worked right with the wiring in this thing.
I want to know what I need to buy for the suspension?to replace everything?also how I should go about it?I also have a ford 9" I want to install I had pads welded on but I dont know if I can run chevy wheels with it or not,Do I need to redrill the axles?Also will the driveshaft fit?
What do I use to clean up the frame and paint it?I have a compressor to use for air tools and such.
I realize you guys cant answer all my questions but any would help this is my first complete restoration and I really dont want to forget something important.
Thanks
Old 04-20-2007, 09:09 PM
MAYNARDTRUCKIN's Avatar
Last journal entry: new pic
to cleen the frame use a meda blaster or a wire brush the parts for the suspention r bushings, ball joints, tie rod ends, drag link. that should be all but if you have any questions you can ask me i have a 70 and specialize in thoes trucks and the parts.
1955 Chevy Truck Streamline55 Introduce Yourself 4 12-06-2007 07:22 PM
Car 235ci into '53 Chevy Truck New2theart Engine 8 10-17-2006 12:37 AM
53 chevy panel truck huligar General Rodding Tech 12 04-27-2006 03:53 AM
94 chevy truck maybe dist./ignition problem,please help! bluesmanjesse Engine 14 11-19-2004 03:31 PM
1996 Chevy 1500 Truck 4.3 V-6 Juicer Engine 8 09-28-2004 06:06 AM
