1972 Dart wiring harness - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2004, 10:43 PM
Lead Heavy '52's Avatar
New Member
Last journal entry: 1972 Dodge Dart - 07/18/04
Is the engine wiring harness in a 1972 8cyl w/ elec ignition the same as a 1972 6cyl w/ electric ignition? Im buying a wiring harness and I believe they are the same. Any opinions?
Old 07-27-2004, 11:02 PM
poncho62's Avatar
Wiki Edits: 5
Probably not. But you can probably make it work. The distributer, alternator etc are in different locations, so you may have to lengthen or storten some wires.
Old 12-27-2005, 12:58 AM
72 dart wiring harness
Howdy, is there a problem w/original? burnt, brittle, bad terminations?
cause you could just split open the harness and replace one wire at a time, and that way end up with a new harness if you think you might have to lengthen some wires anyway
