1972 dodge dart swinger - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2003, 08:27 AM
Lightbulb 1972 dodge dart swinger
i recently purchased a 1972 dodge dart swinger.... it currently has a 225 slant six in it but i would like to put a 360 in.... i was wondering if anyone knew if the engine mounts would match up or if i would have to fabricate them.... i have seen darts with a 318 and being as the block is the same i would think it would match up.... the engine i'm looking at also come with a dana rear??? i'm not sure what that is so if anyone knows i would appreciate it if they could explain....
Old 01-14-2003, 08:39 AM
Post
Hey Rice killer!!
I am building a dart too! I am doing up a 225 slant six. You should too! Check out my forum!
Old 01-14-2003, 08:50 AM
deuce_454's Avatar
Post
as far as i know you will need either a v-8 K member o rsome engine swap motormounts, if i were you i would do an internet search or buy a couple of mopar magazines and i am sure it will turn up
Old 01-14-2003, 09:19 AM
engineczar's Avatar
Post
Deuce is correct. A V8 in a Dart would require a K-member from an original V-8 "A"Body Mopar(Darts, Dusters, Demons, Scamps). Mopar's old performance parts division "Direct Connection" used to carry the K-members but I don't know if Mopar Performance carries them now.
A piece of advice, before you start you should take a look at the area where the torsion bars connect to the sub-frame. These are very prone to rotting out (especially in the snow belt)and if bad enough would need to be reinforced. The extra weight of the V-8 doesn't help the situation. I mention this because it's easier to fix this area while there is no engine in the car.
BSE Racing Engines
Old 01-25-2003, 10:57 AM
kellogs's Avatar
Post
my fist car was a 71 dart swinger with a 340.
tire roasting machine it was.best 600 bucks i ever spent and this was 1993
