I had to use tubular uppers on the 59.
Not enough clearance between the #1 Exhaust and the stock upper arm. 454 in a car that was not designed for a BB. Should be no problem---many are doing it. I have the arms from Airride----were about $300 when I bought em. Seems the range is from about 300 to 600 for these. I have noticed that the uppers are available for the A-Bodies now. Not sure if it is Year-One or NPD (national parts depot) that has them. I think about 129 each. Might want to look into a damaged cross shaft as well, this would be the part that the bolt actually threads into. Perhaps it is stripped or wallowed out to the point it cannot retain the bolt. Remove the control arms one at a time and mark the sides they go on. They look very similar and getting the sides mixed is too easy. Bryan Last edited by Bryan59EC; 09-10-2007 at 06:06 AM. |
The thing that concerns me is the fact that the bolt came out in the first place, i'm wondering if they were torqued in the first place properly. If the threads weren't good to tightnen to spec, than the shafts should have been replaced. The replacement shafts i've seen and also there are 2 differant styles from the factory, but instead of the 5/16" bolt it uses like a 7/8" or so nut. Of course the control arms are probably elongated now, thats because they came loose. I would get another control arm from a junkyard and get new bushings and ball joint installed, IMO I like the looks of a factory car when I look under the hood. And maybe get away from the shaft style with the 5/16" end bolt and use the one with the larger threads and nut.
Btw if you decide to do this yourself this time, make sure the suspension is on the ground before torquing the end bolts/nuts on the shaft. It will put the suspension in a bind if they are torqued with the wheels off the ground. Edit: IIRC the end bolts are 3/8" not 5/16" Last edited by chieftain; 09-10-2007 at 05:42 PM. |
Awesome, thanks for the quick replies.
Yeah, the more I see the more I like Old, stock looking enginebays and the such, but my 72 already has aluminum heads, a different pan, and is about to get an aftermarket AC, so its pretty well messed up already ![]() I think when I steal I mean, work on my dad's 65 with him, I'll push for a more stock look (and... pull the 455 thats in it..) |
It should have a 3/8 bolt holding the washer on and the bushing in place.
I have never seen one with 5/16. If it has the nuts that screw on the ends of the shafts instead of bolts Some Buyer at GM bought off on nuts that were not lock nuts and did not have lock washers in the early 70s. There was a major recall at that time and I spent a lot of time replacing those nuts and washers with a locknut and new washer. If it happened to be one that didn't have the nuts changed they would back off. This is also the reason that you see nuts tac welded on the shaft of the early/mid 70 GM cars. That was the factory fix after they discovered the problem. Cheifton's suggestion to wait until the car is settled on the wheels to tighten/torque the bolts/nuts is a good one that will help prevent squeaks and help the bushings last longer. |
| 81 El Camino Engine Swap Question | newdad1 | Engine | 1 | 06-09-2007 11:17 AM |
| Upper Control arm El Camino | solidaxel | Suspension - Brakes - Steering | 2 | 05-02-2005 02:06 AM |
| El Camino/ neutral safety switch | stinky jinx | Electrical | 4 | 03-15-2005 10:00 PM |
| el camino fenders | amish | Body - Exterior | 1 | 05-16-2003 04:31 PM |
| el camino rear end ?? | mac95 | Transmission - Rearend | 3 | 01-01-2003 01:26 PM |
