Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1972 El Camino differential ID
Old 08-30-2012, 09:32 AM
big gear head's Avatar
big gear head big gear head is offline
High Performance Rear Ends
The 8.2 has a 1 1/8 inch pinion nut and the 8.5 has a 1 1/4 inch pinion nut. The 8.5 has some square corners on the bottom of the casting in the 5 and 7 o'clock positions that can be easily seen from the rear of the car.
The Following User Says Thank You to big gear head For This Useful Post:
rbutler (08-30-2012)
