1972 ford f-150 wheel width - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2007, 09:30 PM
Jr 1948
Last journal entry: frame painted and motor is in
hey i was wondering what the width in the front between wheel to wheel on a 1972 ford f-150 and is it the same as a 1981 ford f-150
Old 12-08-2007, 09:39 PM
powerrodsmike's Avatar
Wiki Edits: 161
I don't believe there is such a thing as a 72 f 150..
there is an F100,250 and 350.
I have a 72 f100 with stock wheels in my driveway...I'll go measure it if you'd like.
later, mikey
BE different....ACT normal.
Old 12-08-2007, 09:41 PM
Jr 1948
yes please that would be very helpful to my project and go from like the king pins are something thanks derrick
Old 12-08-2007, 09:43 PM
Wiki Edits: 161
I will do it in the morning..
It's too cold for that right now.
It must be about 50 degrees out there...Brrrrr.
Mikey
Old 12-08-2007, 09:45 PM
Jr 1948
k thanks cause my dad had his 48 f-1 on a 72 frame and the wheels where inside the fenders and trying to figure out if a 81 ford frame is the same so i can put my 48 on it thanks
Old 12-08-2007, 11:15 PM
WHY ???
Is you 48 frame missing, badly bent or rusted ??
As a general rule ... the BEST frame for a 48 Ford pickup is the frame that came under it ... with upgrades to it ... the original frame.
Old 12-08-2007, 11:16 PM
Jr 1948
Lol i have never had the original frame
Old 12-09-2007, 12:29 PM
Wiki Edits: 161
I went and measured my Old Yeller F100 front end...without taking the wheels off, I measured 75" outside the tires, those are 235-75 r15 tires on 6" rims.
I measured the kingpin C/L at the bottoms and got 57 1/4"
I did some additional measuring and a little math and came up with 66" hub to hub with drum brakes.
The 1970 ford truck facts dealer book I have says the track width of a 70 F100 is 64.4". That measurement is the centerline of the tread on a stock truck with stock tires and rims. The 70 and 72 are about the same exact truck.
HTH, mikey
Old 12-09-2007, 01:56 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
I can't tell you widths.
What I can tell you is that the ford 9" under the trucks from 57 to 72 were the same width. They transplant them in our old trucks all the time. It is almost bolt in for mine.
In 73 the track width got wider on the rear axle. I would assume the front did as well, but I am not positive. The 73+ rear axle will not work under our old trucks unless they are narrowed.
wheel and tire size for 38 ford stoke46 Body - Exterior 1 02-05-2006 01:30 PM
Correct '51 Ford Wheel Offsets landroid Body - Exterior 2 04-30-2003 07:45 PM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 04:38 PM
40 Ford wheel size-help please Randy Owens Suspension - Brakes - Steering 3 03-06-2003 08:41 AM
36 Ford Banjo wheel to a late GM column Django Interior 8 01-07-2003 08:52 AM
