1972 ford f100 long bed trans question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2009, 07:01 AM
72fordlb's Avatar
BARN BURNING BIG BLOCK!
i have a 1972 ford f100 long bed with a 390 and a 3spd. its not a toploader or anything its a motorcraft. how much power can it hold up to. im planing on making the 390 into a 428 maybe and i want to go cheap.
Old 03-06-2009, 11:44 AM
FWIW, it is not horsepower which kills trannies, but shock loading. As long as you drive it normally, it will last forever behind 500hp. Try to shift flat from first to second will kill it on the first try.
thnx, jack vines
Old 03-06-2009, 02:53 PM
72fordlb's Avatar
thnx but im wanting to build it to be a ground pounder ride and i dont plan to baby it along thru the gears. Is there any kits a could buy to make it stronger.
Old 03-08-2009, 12:36 AM
Wiki Edits: 85
Unless you buy specialty gears ($$$$$$$$$$$$$$$$$$), it is usually impossible to make a standard transmission "stronger". Cramming from gear to gear will ruin any standard transmission. Once in gear only major shocks will hurt the gears.
Now if you are planning on flying backwards, then slamming into first gear and stomping on it, your transmission WILL suddenly have extra pieces in it.
Old 03-08-2009, 10:43 AM
woodz428's Avatar
Troll Hunter
I would suspect, and you can verify it by looking, that it is the typical Ford 3 spd that shares many intenals with a Top Loader. If it has a cover on the top...it is. They are plenty strong, probably in the same league as the 4spd Top Loader...just shy a gear.
Old 03-10-2009, 04:50 PM
72fordlb's Avatar
thank you. i have done some reading and people keep saying thay r VERY weak. i believe you but im alittle worried about the other info.
'59 Ford F100 Pickup with Buick engine birdman1 Introduce Yourself 5 11-14-2010 04:23 PM
A question for the solid axle, king pin, early ford spindle kind of guys... Centerline Suspension - Brakes - Steering 11 02-17-2008 03:57 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
ford truck bed trailer for my chevy good idea? IHAVECHEVYPARTS Engine 8 11-14-2002 02:08 AM
Ford Engine To Trans Help davesr Engine 1 01-05-2002 08:27 AM
