1972 nova 350 engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2009, 05:19 PM
watchdude1's Avatar
HI
I have a guy selling a t5 trans for $900.00 is that a good price? I saw one on ebay for $350.will it go in a 1972 Nova with 350 engine and 4 speed muncie m21 I want to replace it with a 5 or 6 speed but don't want to break the bank or do to much cutting of the car is this the best trans for my nova?
i guess that the trans mount is not located in the same place, I was also thinking of puting a 454 in my nova will it fit with my 350 motor mounts?
Thanks
Old 05-18-2009, 06:48 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
The T5 is a week transmission, it would probably be okay w/the 350, but I think the BB is to much, price $350. $450. why do you want to change to the 5 speed?
Get BB mounts, then test fit the engine, get it where it needs to be & mark the location, then either drill new holes or weld the bottom of the mounts in.
You might want to install frame connectors w/t BB
There are BB front coil springs? you may need a larger radiator as well + exhaust, fuel system, what about the 10 bolt? just some things to think about.
Rich
Old 05-19-2009, 07:59 AM
I buy good T5's for around 500.00.
great transmissions but a little weak. shift them slow and avoid clutch drops and they will hold a lot of power. avoid drag slicks.
Old 05-19-2009, 05:41 PM
watchdude1's Avatar
my nova has new 12 bolt eaton 373 gear rear and m 21 4 speed with 350 bored 30 over solid lifters, it tachs at 4 k around 60 mph I would like to be able to drive on the highway with out so many rpms what is the best trans for this. I already tried 265 x 15 tires .
I went to island dragway did 13.5 at around 134 mph in the quarter was taching around 8k at the end of the quartermileif i had another gear I could do better in the 1/4 mile right.?
Old 05-20-2009, 07:10 AM
what??
13.5 et at 134 mph?
134 mph trap speed means your engine is making over 650hp and should be running high 9's or low 10's in the 1/4 mile.
105 mph would be more suitable for a 13.5 et.
if the engine is revving at 4000 rpm at 60 mph then it should be revving 9,000 rpm at 134 mph.
the car would need to have a 5.54 gear to rev at 4000 rpm at 60 mph with a 28 inch tire. Are you sure the tach and speedo are right?
a 3.73 gear, 27 inch tall tire, and 4 speed should rev at 2800 rpms at 60 mph.
A T5 works nicely for a 12 second car. just don't beat it up. shift a little on the slow side and it will live a long life.
Old 05-22-2009, 07:04 PM
watchdude1's Avatar
I need to check my tach and look at my 1/4 mile slip again
Old 05-22-2009, 08:45 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 454C10
what??
13.5 et at 134 mph? *snip* 105 mph would be more suitable for a 13.5 et.
YOW! Or even 95 MPH for a 13-fifty.
But if you were hitting 134 MPH, you'd be all like, "This thing is awesome!"
And the tech guys would be telling you to PARK IT until you got a cage, etc.
350 sbc upgrade... Engine will not start FenderGitars Engine 10 10-08-2010 03:26 PM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 11:53 AM
We pulled our 350 and trans for our beetle project - pics zbhover Engine 3 10-06-2008 03:40 AM
350 chev engine numbers forpetesakeorg Transmission - Rearend 2 08-18-2003 07:11 AM
350 or 455 olds engine? franny Engine 2 11-29-2002 09:32 AM
