Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 12-25-2005, 10:55 PM
leejoy leejoy is offline
72NOVA454
1972 Nova Rear End
Does my 72 Nova have one of those good strong 8.5" 10-bolt rear ends. I read some article where they are as strong as 12-bolt units but only if they have the 8.5" ring gear with the 11/16" ring gear bolt heads. I guess the only way to find out is to remove the cover right?
Old 12-26-2005, 05:55 AM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
re: 1972 Nova Rear End
Sorry, if stock, yours will have the old lightweight cruncher in it..
Old 12-26-2005, 08:15 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Moderator
The 10 bolt is strong, but not as strong as a 12 bolt. You will find that as the HP builds and you start to hook the car up that the axle housing will rotate off the spring perches. You can prevent this from happening by installing "U" bolts over the axle tubes and doing away with the stock mounting method.
Vince
Old 12-26-2005, 08:20 AM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
 Crosley's barnstar
Vince
We would add some flat steel material from the inside edge of the spring perches .... over the axle tube to the other side of the perch. This would keep the perches from curling up then allow the axle rotate / rock forward - back wards.
just a thought
Be kind to your children... some day they may be decide what nursing home to put you in
Old 12-26-2005, 02:48 PM
camaroman7d's Avatar
camaroman7d camaroman7d is offline
The 8.5" and 8.2" can be identified without removing the covers. The housing itself has a slightly different shape. If you have an 8.5" there should be two little "ears" sticking down on each side of the center section.
Yes, a properly built 8.5" is VERY strong. They are very close to a 12 bolt built the same way. Very little difference as far as strength.
Depending on how much power you are making or how fast you are trying to go there are things that can/need to be done if you want it to live. Even 8.2" 10 bolts can take more than most give then credit for. I know of one that has been low 11's for quite a while in a 3400lbd Camaro. It finally let go (broke a gear) when he dipped into the 10's. I am not saying you should attempt to do that since the 8.2" is quite a bit weaker (they both have te same axle spline). The gear in the 8.2" is the weak link.
Old 12-26-2005, 10:50 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Depends a lot on shock loading and pinion crush sleeve flex.
Use a solid sleeve and
Take up the slack in the gears before launching. Manual trans power shifting spells trouble with good traction.
Old 12-27-2005, 09:07 PM
72Orange 72Orange is offline
Follow this link for some good info on Nova diffs.
And yes, the 8.5" is nearly as strong as a 12 bolt.
http://novaresource.org/axle.htm
Old 01-03-2006, 02:07 AM
jimfulco jimfulco is offline
Sometimes the axle tubes will spin in the center housing, too. Get them welded if you plan to use it hard.
Old 01-05-2006, 08:56 PM
95th67cam 95th67cam is offline
I pulled a open 3:08 8.5 rear end out of a 74 Nova and stuck it in my 67 Camaro. So a few of them had 8.5's. I swapped in a limited slip from a 86 caprice cop car with no problem for a cheap limited slip rear. the 3:08 kind of stink though.
Old 01-07-2006, 01:05 AM
'71 was the last year of the 8.2" rear in the Novas. They went to the 8.5" unit in '72. SS's had multileaf springs, but the rest got monoleafs. In '73, they all got multi's.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "1972 Nova Rear End"
66 nova rear end robbysapien Transmission - Rearend 5 08-01-2007 07:48 PM
Nova Rear End - Wide Tires Delirious2000 Transmission - Rearend 3 07-06-2006 02:48 PM
64 nova rear end width risaacp Transmission - Rearend 2 05-05-2004 12:03 PM
70 nova rear end 355'swhat no.splines oldnable Transmission - Rearend 5 07-18-2002 11:39 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
