#1
1972 pontiac engine suggestions?
Ive been steadly modifing my 72 firebird. from the auto turbo 350 trans to a 4-speed muncie.
since its the weak 180hp 350 with the 2 bbl rochester and 7.6 compression ratio, ive found a few parts. -an edelbrock preformer manafold -600 holley even bore carb -and a set of heads off of a 400. the head is 87cc -and a set of long tube headers. How much should i gain torque and hp wise with these? i was thinking 50 from the 4bbl and another 70 from the compression ratio increase. any thoughts? Register now (free) or login to remove ads |
#2
The '74 350, with a 4bbl, #46 heads (86cc, 7.6:1 comp), and an 066 cam made 200 net hp. The 066 cam has 273/282 duration and .406 lift, compared to your 555 cam with 269/277 duration and .374/.406 lift. You cant just add X amount of hp for this, and Y amount for that. Everything has to match everything else. Last edited by WDCreech : 06-28-2010 at 05:06 PM. |
| Thread Tools | Search this Thread |
| Similar Threads for: "1972 pontiac engine suggestions?" | ||||
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| Knowledge base | Dave57210 | Site Suggestions and Help | 2 | 12-20-2009 07:06 PM |
| 383 engine tapping and oil burning- weird | RowShan | Engine | 15 | 10-10-2009 05:07 PM |
| 1985 C-6 truck tranny, no engine braking effect | fast68 | Transmission - Rearend | 40 | 02-04-2008 05:55 PM |
| Engine mysteriously died, need suggestions please | Mad Maggot | Engine | 12 | 08-28-2007 08:13 PM |
