1972 Pontiac firebird upgrade questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2010, 03:11 PM
Ive been steadly modifing my 72 firebird. from the auto turbo 350 trans to a 4-speed muncie.
since its the weak 180hp 350 with the 2 bbl rochester and 7.6 compression ratio, ive found a few parts.
an edelbrock preformer manafold
600 holley even bore carb
and a set of heads off of a 400. the head is 87cc
and a set of long tube headers.
How much should i gain torque and hp wise with these? i was thinking 50 from the 4bbl and another 70 from the compression ratio increase.
any thoughts?
Old 06-28-2010, 03:57 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site,
Cole
Old 06-28-2010, 04:39 PM
ericnova72's Avatar
More for Less Racer
Your estimates are real high. I would not expect the carb and manifold change to make more than 30 hp, and the compression ratio change to make more than 15 hp.
Rule of thumb on compression ratio is 1 point of compression is good for roughly a 3-4% increase in power, starting from a real low compression ratio like you have it might be 5-6%. The higher you go in compression the less a change returns. To go from 13 to 14-1 might only gain 1/2-1%.
The headers maybe another 15hp.
Old 06-28-2010, 07:26 PM
KMyA
While you are upgrading you may want to consider a cam. I have a Summit 2802 cam for my pontiac 400
bt
Old 06-28-2010, 08:52 PM
bt
Yea I would really love to, but there is the problem of money. If i come across a cam that i can get for a cheap price then id do it. the parts ive gotten have been given to me and what i had laying around haha.
Old 06-28-2010, 08:57 PM
WDCreech's Avatar
Grumpy Old Goat Herder
AndersonRacing, see my reply to your other post, in this forum.
Bill
350 sbc, 77 Pontiac Firebird Birdman77 Engine 1 09-18-2008 08:38 PM
Pontiac Firebird Project Bryan Meier Engine 2 05-06-2008 09:08 PM
Some simple questions ref. my 67 Pontiac tk421 General Rodding Tech 2 12-21-2007 08:14 AM
Gross to net HP conversion and more Pontiac questions Wmarden Engine 6 11-18-2002 03:28 PM
87 pontiac firebird chevyelc81 Engine 3 04-15-2002 09:47 PM
