Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1972 pontiac lemans 350 build
  #19 (permalink)
Old 02-20-2013, 07:05 PM
gearheadslife gearheadslife is offline
Originally Posted by LATECH View Post
A 350 poncho has a small bore. 3.875 in
The heads with the larger valves create a flow problem as the valve is too close to the cylinder and "shrouds" the valve decresing flow.
350 have chamfers at the top of the cylinder to help unshroud the valve and inprove flow.
I wouldnt spend much money for heads for a 350.
If the motor is running , i wouldnt do anything but a cam and some carb work. And some dizzy tuning.
Even milling the heads that are on it would raise the cost as you would need to make the valve train adjustable.
I have a good running 350 in my poncho. Its coming out this summer for a 389 replacement.
I am even questioning that I have a 428.
I will mothball the 350 for anything I get in the future that may need an engine to be a driver.
I hear ya, BUT.. many a poncho guy has started with a 350 and then moved to a 400 or 389/455/421/428 ect.. I loved my 326.. it reved as far as the points would allow it.. cast rods should have left the building many times over.. but didn't.. what a fun engine.. just needed a lite car
