1972chevy no action - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2013, 02:28 PM
1972chevy no action
Have a 1972 Chevy c10. Turn key and nothing happens. Has new battery. Pull lights on and nothing happens. Cables from battery are good. Turn key and no panel lights or gauges register either. Any ideas?
Old 02-11-2013, 03:16 PM
T-bucket23's Avatar
Wiki Edits: 26
If you jump the starter (large post to s terminal) does it crank. If so you may have a blown or disconnected fusible link. On the large stud on the starter there is generally the battery wire and up to 3 others. These others feed everything else generally.
If you jump the starter and it doesn't crank either one or both of your battery cables has a bad connection.
Chet
Old 02-11-2013, 03:20 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Look for a fusible link in the system near the battery, something that looks like the picture. It is probably blown and needs replaced.
Old 02-11-2013, 03:56 PM
Battery
Yep, sounds like a fuseable link. True, try jumping accrossed starter solenoid posts and see what happens. May also be a bad block ground.
Old 02-11-2013, 05:48 PM
As my Dad would always say make sure not to use a good screwdriver
SUN 500 In Action Custom10 Hotrodders' Lounge 10 01-10-2011 06:22 AM
Can't git no journal action topfuel55 Hotrodders Site Suggestions and Help 3 12-12-2007 11:42 AM
DA-Dual Action only? jcclark Garage - Tools 2 10-23-2006 05:14 AM
Legislative action OneMoreTime Hotrodders' Lounge 0 11-24-2005 01:56 PM
Missing in action? red347 Hotrodders' Lounge 9 11-24-2004 12:35 PM
