Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1973 429 engine
Thread: 1973 429 engine
Old 11-22-2009, 03:12 PM
old76c10's Avatar
old76c10 old76c10 is offline
all jacked up on mountain dew
those numbers sound like the casting number for the heads the block casting should be around where the starter goes toward the rear of the block and unless you have head castings DO0E-R you will have a pretty plain engine the pre 72 heads are the good ones also i think pre 72 block deck height is shorter
