Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1973 429 engine
Thread: 1973 429 engine
Old 11-23-2009, 04:06 PM
327NUT's Avatar
327NUT 327NUT is offline
Jrbowman......good info but the properly combined parts will turn that "plane Jane" 429 into a stump puller! Google "429 Ford engine build" and see the Car Craft magazine article using Edelbrock alum. heads. You can't always take everything these mags tell you as gospel but this build is pretty straight forward with good results. The heads are not cheap......but they will add a ton of performance and also reduce a ton of weight.......good luck.
