1973 429 engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2009, 10:27 AM
1973 429 engine
I have a 1973-429 engine , with the block id numbers as D3VE-A2A . I need to find out what type , cj,scj or plain 429
Old 11-22-2009, 04:12 PM
old76c10's Avatar
all jacked up on mountain dew
those numbers sound like the casting number for the heads the block casting should be around where the starter goes toward the rear of the block and unless you have head castings DO0E-R you will have a pretty plain engine the pre 72 heads are the good ones also i think pre 72 block deck height is shorter
Old 11-23-2009, 10:19 AM
ericnova72's Avatar
More for Less Racer
Just plain 429-460, there was no SCJ or CJ stuff after '71. The "D3" is 1973 casting code.
Old 11-23-2009, 05:06 PM
327NUT's Avatar
Jrbowman......good info but the properly combined parts will turn that "plane Jane" 429 into a stump puller! Google "429 Ford engine build" and see the Car Craft magazine article using Edelbrock alum. heads. You can't always take everything these mags tell you as gospel but this build is pretty straight forward with good results. The heads are not cheap......but they will add a ton of performance and also reduce a ton of weight.......good luck.
Old 11-23-2009, 07:07 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Not exactly so, Ford did make the 460 Police Interceptor in 72 and 73 that used the CJ/SCJ heads,rods, etc.... Technically they are not CJ/SCJ engines but they are close enough.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Trouble trying to start engine for the first time. Z-Money Pit Engine 8 10-29-2009 10:02 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 01:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
pontiac engine noise, possibly rod knock? Blob Engine 4 08-06-2006 03:01 PM
