1973 buick 455 more power from all stock? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2012, 07:19 PM
hey im 19 and i know the basics about engines but i dont know engines alot tho,i own a 1973 buick riviera with the buick 455 thats all stock without air conditioner if that matters, im just wondering how could i get a bit more power out of it without removing the enigne or rebuilding it ect...im not very rich so i cant rebuild it due to not enough money, but i have some cash flow to make a few changes under the hood. wats a fwe things i should replace to add horespower to it? to you guys that own 455's wats a good carb to put on it that can go with the original intake? and can i upgrade the cam at all without getting new heads or intake or anything else like that? i get about 400$ a mounth so im not rich. and to anyone that has owned a 73 riviera whats a good muffler to put on that sounds mean and has a rumble at idle and take off? flowmaster magnaflow cherry bomb glass pack? ect... its duel exhaust without cats by the way. and also would an engine like that running too lean or running too rich affect the horespower? and how do i tell if its running to lean or rich? im a rookie, im just learning about engine's
Old 03-11-2012, 08:54 PM
BOBCRMAN@aol.com's Avatar
73 is a low compression engine. The only way to build horsepower is to build cylinder pressure.
The old stock class drag racers used to run total advance in the ignition as high as 50 degrees BTDC. This and a reground camshaft that helped build cylinder pressure made these cars very fast. For their size. The Q-jet carb can be made to run well also. But, it ain't cheap. and the stock rear end gear ratio on that car will never be a world beater..
Old 03-12-2012, 04:29 AM
Clean up/rebuild the Rochester carb. its perfect for that motor if its operating correctly.
Do a compression test to make sure all is well with the engine. Make sure it has a quality cap/rotor, wires and plugs. Make sure your vacuum, and centrifugal, advance work on the distributor. Advance the timing 6-10 degree's(you will have to experiment to get the best setting) Listen for spark knock caused by too much timing or low octane fuel( You may have to run premium, depending on timing)
Changing the rear axle ratio is a help for those cars. Most have 2 series gearing, changing to low to mid 3 gearing will add a big punch for that car, but you'll probably lose some MPG do to the higher cruising rpm.
Adding a set of headers connected to your dual exhaust will let the engine breath better, picking the power level and torque up a bit.
1973 buick electra 455 kruzerman01 Engine 2 01-19-2012 07:57 PM
posi/disc brake rearend for 1973 buick century Rafael Transmission - Rearend 0 09-03-2011 07:32 PM
stock 1973 el camino 350 73elco Engine 5 06-28-2007 05:21 AM
Refirbishing 1973 and 1974 stock rims. topdogger Suspension - Brakes - Steering 2 09-26-2006 05:49 PM
