1973 Ford Windsor 351 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2010, 07:49 AM
Hey guys first post and first Ford Engine Build. I am currently building a 1946 ford f-100 hot rod pickup. I bought the truck the 1973 351W in it.
From what I understand the windsor is the desired block and the cleavland has the desired heads. I however do not want to build a clevor. So this is what im thinking.
The truck is going to weight in the neighborhood of 2000lbs. so I do not need stupid power. The block is a good block so im thinking of putting GT40 heads on the top end, run an edelbrock performer 2181 intake for windsors and a 4bbl edelbrock 2506. However what I do know about this year windsor is the low hp rating. I assume it is bc of the junk cam and pistons. What would you guys reccomend for a mild hydraulic cam and new non domed pistons. I want to run non forged bc I do not want to drop thousands in this motor im hoping around $500 bc i already have the intake and carb.
Need some suggestions bc I do not know where to start.
Thanks
Bret
Old 08-20-2010, 11:42 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Bret,
I think for what your going to pay for gt40 heads you'd be better off looking for an after market set of heads, world's Windsor Jr heads is what I'm using they have 58cc chambers (vs gt 40s 64cc) new bare heads are $330 each, assembled $560 to $760 each or keep looking you may run across some used trick flows or AFR's, (FYI 93to95 lightings had gt40 heads.)
Pistons, I'm using flat tops but i have a high power engine, the pistons below are at jegs $42.99
http://www.jegs.com/p/Sealed-Power/S...55702/10002/-1
# 351W Stock-Type Piston, .030'' OverborePiston Dia.: 4.030''
# Piston Top: -13.2cc Dish
# Pressed Pin
# Comp Ratio: 9.30:1 w/60.4cc Heads, 9.08:1 w/69cc Heads
# Ring Grooves: 5/64'', 5/64'', 3/16''
# Sold as Each
cam, I'm using a roller but I assume your using a flat tappet
Lunati Part# 638-00064LK Adv. Duration: 284�/284�
Gross Lift: .488''/.488''
RPM Range: 1500-5500 $169.99 .
There's a start, I'm sure others will chime in with more information.
Good luck,
Rich
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 06:14 AM
All right all you Ford guys, a couple of questions Shades_o_Grey General Rodding Tech 8 12-28-2010 06:00 PM
Ford 9 Inch Posi Swap 31fordcoupe Transmission - Rearend 11 11-06-2009 09:38 AM
Ford Muscle..what's wrong with them? tm454 Hotrodders' Lounge 41 11-20-2006 12:37 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
