1973 Nova fuel line question... - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2012, 09:08 PM
67MercCat's Avatar
Junkyard Dog
Hey guys I just got a 73 Nova i'm working on and I noticed that there's two lines coming from the fuel tank. One leads to the mechanical fuel pump and the other leads to a spot right beneath the brake booster, but it's not connected to anything. I capped it off for now to spot junk from getting in there but what is that all about, anybody know? The engine is 327, carburated.
thanks
Old 07-26-2012, 01:57 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
thanks
IIRC originally it went to the charcoal evaporation/emissions canister.
Found a drawing, click on it for more info:
Old 07-26-2012, 09:50 PM
67MercCat's Avatar
Junkyard Dog
thx man, I guess i dont need it and I can cap it off, I dont see a charcoal evaporation/emissions canister anywhere in the engine bay. I figured it was thrown away quite some time ago. I dont suppose it would affect anything now would it?
Old 07-27-2012, 06:15 AM
S10 Racer's Avatar
http://www.warsprints.com
I think those were used before vented gas caps came about. If you have a vented gas cap, you may be ok. The tank has to be vented someway.
Old 07-27-2012, 01:23 PM
67MercCat's Avatar
Junkyard Dog
Ah ok, I'm going to go ahead and check the cap and make my determination from there.
Also as far as electrical goes, all I have to hook up is the Alternator, Starter, coil and distributor wires to get it going. The wires are all there and I dont think theres anything else to it with such a simple system. I'm trying to get it rolling today.
Old 07-27-2012, 01:43 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That's right, you can see in the last diagram it provides a means for venting the tank. In another car I used a fuel filter, pointing downward in a protected area inside the fender to protect it from water, etc. to serve as a vent because I didn't trust the gas cap alone would have enough flow to keep up w/the fuel flow out of the tank along w/the changes in tank pressure from temperature.
fuel pump lines plug
fuel line question dboyett Engine 3 11-09-2006 04:38 PM
Fuel line question silver956 General Rodding Tech 9 11-14-2004 04:40 PM
Fuel line size question 52Caddy Engine 2 07-01-2004 12:54 PM
Fuel line question stea Engine 8 06-01-2004 03:59 PM
Fuel line question Camaro2Fast4u Engine 5 03-07-2003 06:12 PM
