1973 plymouth duster - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2003, 11:12 PM
SpcHorn's Avatar
Question 1973 plymouth duster
does anyone know where i can find some black leather seats that will fit in my 73 duster? i also need a dash.
in the Dallas and Greenville TX area if possible, thanks
Old 08-01-2003, 01:28 AM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
I dunno about the dash, but for the seats - just measure the space you've got to work with, go to the scrap yard, and look for seats from RECENT wrecks.
Alan
54 Chevy Pickup
Old 08-02-2003, 04:28 PM
SpcHorn's Avatar
Question seats for Duster
im looking for seats for my duster, its got a slant to the body inter. were the bolts go, and i don't know if any other seats would fit in there, thats the back seat. the front shouldn't be that hard to find. if someone could help be with that, that would be great. ill post measurements from bolt to bolt later today.
Old 08-02-2003, 06:18 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
as far as finding a direct bolt in...... you may be disappointed...... you very well might have to find you a couple of seats you like, and fab up some mounting bracketry......
Old 08-15-2003, 11:23 AM
SpcHorn's Avatar
73 duster
thanks for the help, i just wish that i could find an old 73 that i could buy and redo thoughs seats, and they would fit perfect. but if i cant find original seats ill just have to make it work.
again, thanks for all the help
spc Horn
Old 05-20-2010, 03:26 AM
I`ve been scouring everywhere for buckets for my 75 Duster. Bout all I can find close to original are in pretty poor shape and people are wanting up to 1000 for them. As much as i would like to go with "original", I think I`m just going to bite the bullet and go with a pair of nicer padded racing seats.
Old 05-20-2010, 01:43 PM
a70dart's Avatar
I can tell you that import seats are a pain to try to install. The way the floor is made in your Mopar makes it hard without major fab work to install any non factory seat. I have installed several of the seats that you can get from Summit and some of the padded racing seats.
Pop an extra 100$ a seat and get the seats that tilt and you will be happier.
The flat slides work well, you will need to put them on the left inside of the tracks, but it works.
They will also fit in between the factory hump/valleys of the original seat mount areas. You will have to shim them up a bit to you liking, I did mine one inch in rear and a half inch in front. Has worked great on each car I have built. Unless you get lucky and get a Mopar with buckets that are in great shape, The cost of the seat cover kits will run almost as high as the after-market seats.
Good luck!
Old 05-22-2010, 10:18 PM
DanTwoLakes's Avatar
Wiki Edits: 22
You realize that this thread is 7 years old, right?
Old 05-22-2010, 10:25 PM
Wiki Edits: 22
The new seats are not the problem. The mounting brackets that presently attach to the floor of your car to level the original seats can be used and the new seats can be adapted to fit those OEM mounting brackets.
Old 05-23-2010, 01:45 PM
a70dart's Avatar
Oh, that is right if you have those parts to adapt the new seats, but as for most of the cars I've found have either bench seats or none ata all.
Yes I do understand that all prior replays other than the one just before my first was 7 years old. casehd needed some info, dont be so critical lol.
Old 05-23-2010, 06:58 PM
Wiki Edits: 22
The point is that starting a new thread would have worked just as well or better than adding to an ancient one, and my comment was intended for casehd, not you. The chances of any of the people in the old thread still being around are very small. I wasn't trying to be critical, just doing my job as a moderator.
Old 05-23-2010, 09:47 PM
a70dart's Avatar
I'm sorry I was so critical then
Old 05-24-2010, 02:28 PM
Wiki Edits: 22
Not at all, I realize you were just trying to help him.
