Hotrodders Bulletin Board
#1
1973 VW tail light diagram (electrical)
I own a 1973 VW Beetle. It has been enhanced in many ways from suspension to engine. From tire/wheel size (16 front 18" rear) to exhaust, - the whole bit.
I successfully injected a 540 hp 1987 Turbo Porsche into the bug - with a 6 speed, - covered the inside with a 5 point roll bar and left all else simply stock with the exception of removing all the chrome and front bumper and adding a set of HELLA 7" driving lights and a front spoiler. OK enough of the bragging, I did this all by myself - but I have a problem which to the very best of me I have trouble with. I am not good at auto electrics and this bugs me. My driver side rear tail light wiring. This is what I have. a 3 light-bulb assembly. (three bulbs on what I call a tree) (it may be an after-market assembly) On top is the blinker bulb - 1 metal prong (single filament bulb behind yellow casing) , below is the break light and driving light - 2 metal prongs ( dual filament behind red tail light cover) on the bottom is the back up light - 1 metal prong (single filament behind white casing in tail light cover. I have 5 wires coming from the car. 1 light brown. 1 red 2 white 1 black. HELP , do you know which way they run?is there a color combination for each light? |
#2
re: 1973 VW tail light diagram (electrical)
Get you a test light and turn on one circuit at a time. turn on your running lamps and see which wire gets power on it and wire it like that. you should have 4 wires that get power when you turn on your signals,tail lamps,brk lamps,and backups leaving one wire for a ground. if you need a more in depth procedure let me know.
GL, Tech |
Back to top |
Similar Threads for: "1973 VW tail light diagram (electrical)"
| 65 impala tail light trouble | low65chevy | Electrical | 15 | 07-14-2008 12:50 PM |
| Tail Light Question | horvath | Electrical | 3 | 03-08-2003 03:17 PM |
| 34 chevy tail light | toadman | Body - Exterior | 6 | 03-01-2003 05:01 AM |
| LED tail light conversion | zonk | Electrical | 14 | 01-24-2003 12:20 PM |
| Tail Light | 66chevy2ss | Electrical | 6 | 08-29-2002 04:21 AM |
