We're winning the case!
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 08-24-2008, 08:53 AM
SanctimoniousPrick SanctimoniousPrick is offline
1973 VW tail light diagram (electrical)
I own a 1973 VW Beetle. It has been enhanced in many ways from suspension to engine. From tire/wheel size (16 front 18" rear) to exhaust, - the whole bit.
I successfully injected a 540 hp 1987 Turbo Porsche into the bug - with a 6 speed, - covered the inside with a 5 point roll bar and left all else simply stock with the exception of removing all the chrome and front bumper and adding a set of HELLA 7" driving lights and a front spoiler.
OK enough of the bragging, I did this all by myself - but I have a problem which to the very best of me I have trouble with.
I am not good at auto electrics and this bugs me.
My driver side rear tail light wiring.
This is what I have.
a 3 light-bulb assembly. (three bulbs on what I call a tree)
(it may be an after-market assembly)
On top is the blinker bulb - 1 metal prong (single filament bulb behind yellow casing) ,
below is the break light and driving light - 2 metal prongs ( dual filament behind red tail light cover)
on the bottom is the back up light - 1 metal prong (single filament behind white casing in tail light cover.
I have 5 wires coming from the car.
1 light brown.
1 red
2 white
1 black.
HELP , do you know which way they run?
is there a color combination for each light?
Old 08-24-2008, 09:46 AM
justacertifiedtech's Avatar
justacertifiedtech justacertifiedtech is offline
or was that certifiable?
justacertifiedtech's barnstar
Wiki editor
Last wiki edit: How to find an electrical drain
Wiki Edits: 3
Get you a test light and turn on one circuit at a time. turn on your running lamps and see which wire gets power on it and wire it like that. you should have 4 wires that get power when you turn on your signals,tail lamps,brk lamps,and backups leaving one wire for a ground. if you need a more in depth procedure let me know.
GL,
Tech
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "1973 VW tail light diagram (electrical)"
65 impala tail light trouble low65chevy Electrical 15 07-14-2008 12:50 PM
Tail Light Question horvath Electrical 3 03-08-2003 03:17 PM
34 chevy tail light toadman Body - Exterior 6 03-01-2003 05:01 AM
LED tail light conversion zonk Electrical 14 01-24-2003 12:20 PM
Tail Light 66chevy2ss Electrical 6 08-29-2002 04:21 AM
