Thread Tools Search this Thread share on Facebook
  #1
Old 01-23-2009, 11:05 AM
carcrazychris18 carcrazychris18 is offline
1974 302 help!
i have a built 74 302 and i have misplaced some of the water pump bolts i need to know what size bolts i need to go buy ive looked all over google and no one has the sizes so if anyone happens to know the standard size of a 1974 ford 302 water pump it would be extremely helpful. thanks
Register now (free) or login to remove ads
Old 01-23-2009, 11:14 AM
sunsetdart sunsetdart is offline
Chris.........best advice is to look at the bolts you have. Most are 5/16x18 thread. So knowing what size thread you need, it's only a matter of going your local hardware store and getting the right length and size.
Old 01-23-2009, 11:16 AM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
This SHOULD be in the basics forum. You mentioned misplacing some of the bolts, not all of them, since they use several lengths...which ones??? It would be easy to go to a wrecking yard and pull the ones you need. That's as helpful as it can be with the parameters of the question.
Old 01-23-2009, 11:34 AM
DaSouthWon's Avatar
DaSouthWon DaSouthWon is offline
I put up the tools against$300
If your trying to figure the length you need, cut a piece of straight wire off of a coat hanger. Hold the water pump in place with a couple of bolts, stick the wire in the hole until it bottoms out. Measure. Buy bolts a smidge shorter.
Old 01-23-2009, 04:09 PM
KULTULZ KULTULZ is offline
aka Duke of URL
Do yourself a favor, and me personally a favor. Don't try to mix and match HOME DEPOT CHI-COM crap to your car.
- http://amkproducts.com/Ford_Fastener_Kits.asp
Scroll down to water pump kit.
Old 01-23-2009, 04:37 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
you can get a timing cover and water pump bolt kit out of jegs.$30 or like they said in the other post measure and get alittle shorter.or find an old engine and get the bolts. cole
Old 01-25-2009, 06:30 PM
i know how to find the length ive tryed all the bolts on my cart and am not sure what the thread is thats the only thing the length is no problem
Old 01-25-2009, 07:04 PM
eloc431962's Avatar
Wiki Edits: 37
the bolt should be a 5/16 bolt.i think it is a course thread but not real sure.if you have a 5/16 course and a fine thread bolt handy you can find out.just trying to help. cole
Old 01-25-2009, 07:19 PM
eloc431962's Avatar
Wiki Edits: 37
you said you lost some of the bolts.so can you take one you have not lost and use it to get more bolts.
Old 01-26-2009, 01:56 AM
JeffB's Avatar
JeffB JeffB is offline
Last classified ad: 1965-71 Chilton A/C and...
You might try your local Ford parts dept some listings go back a ways,I just bought some steering column parts for my '54 at the Dealer.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1974 302 help!"
ThreadThread StarterForumRepliesLast Post
302 chevy engine messNaythanOldskoolEngine1712-18-2008 12:04 AM
Clevor Boss???matts94scEngine3301-23-2008 08:51 AM
Building A 302 ChevyScorpio Shaping FlowHotrodding Basics601-16-2007 05:55 AM
can i destroke a 351 w with a 302 or stroke a 302 with a 351w?jims84gt350Engine504-02-2006 01:04 PM
Chevy 302purplenovaEngine610-25-2002 07:26 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
