Sounds like a vacume problem if I was u that's were I would start
It may be a vacuum problem, but I think that it is more likely a fuel delivery problem. Check your fuel filters, including the one in the carb, if applicable. Also check your fuel pressure from the pump.
Bill |
X 3 it sounds like a fuel starvation problem. Start b y checking fuel volume from the new pump.Even if it is new it may not be delivering, the sock in the gas tank may be plugged.
work from there to determine if the carb is getting fuel, maybe the float is stuck or set WAY to low. New doesnt allways mean good. I found that out a few times.
Fact is stranger than Fiction |
Vacuum advance working?
Busted vacuum advance?
You probably should check your point gap. I think it should be .017, as the rubbing block wears down it tightens the gap and retards the timing. Also it's very important to torque sbf intakes properly (inside out).
Sometimes the outer ring of the harmonic balancer slips, even though it reads perfect the engine is running with retarded timing. This would cause the hesitation.
You can verify TDC with a degree wheel and a piston stop or simply advance the timing until you get some spark rattle (detonation), then retard the timing just enough to eliminate the rattle. |
accellerator pump ?
Is the Accelerator pump squirting when you look down the carb, engine off and open the throttle, are the throttle plates seated correctley , poor transition between idle and run, sometimes the carb needs rework. and I know some 351 and 302's use different head bolts. dowell pins and indexed correctly, Manifold fit. ?
yes brand new carb everything working on carb, and yes the correct intake and gaskets. I'm thinking something electrical now, have 6.3 fuel pessure. it idles great starts without touching gas pedal.
302 heads on a 351 may give you too much compression ratio.58- 60 cc 302 chambers vs 65-70 for a 351 |
problem solved
I would have never believed what the problem was. The Ignition Module showed good when tested but a good friend said that dont mean its good. I bought a new Ignition Module today and truck runs perfect. thnx for all the advice everyone. I never had been stumped like that before I was pulling my hair out.
| 351 Modified vs. 351 windsor vs. 351 cleavland ? | Blackbob | Engine | 78 | 01-27-2013 04:15 AM |
| Vaccum problems on a 351 Windsor | oldfordtrucker | Engine | 2 | 06-13-2010 01:08 AM |
| 351 windsor swaped with 351 modifed | fordboy210 | Engine | 6 | 09-02-2008 10:22 PM |
| Dristributor problems 351 Windsor | madesen | Engine | 1 | 04-12-2007 09:39 PM |
| Distributor Problems 351 Windsor | madesen | Introduce Yourself | 4 | 04-12-2007 08:49 PM |
