#1
1974 Eldorado coolant flow problem
I'm completely stumped here. I have a completely stock 1974 eldorado. the car has a brand new radiator, and new thermostat I just installed (yes facing the right direction). Randomly, something gets blocked up in the system and coolant/steam will shoot out of the upper radiator tube where it meets the thermostat housing. When it gets like this, the upper hose because rock hard from pressure and it will stay like that for several minutes before all steam is evacuated. Now, the interesting thing is, nothing is flowing into the coolant overflow can... that is.. until I flip the pressure relief valve on top of the radiator cap, then coolant and steam shoot into the overflow canister! I grabbed every coolant tube everywhere and they all seem warm, and they have to be because I know it is flowing at least some of the time because the heat/defrost works in the car.
this problem was happening before I replaced the old thermostat which I propped open thinking it was the problem, and it seemed to fix the problem, but when I replaced it with the new one I noticed it wasnt propped open anymore so this makes me think the problem is random and I cannot solely blame the thermostat. Im thinking either I keep getting bad thermostats, or the coolant is getting blocked somewhere by something maybe in the head or heater core??? And why does my coolant overflow only work when I flip the valve on the radiator cap? In the tube that goes from the head to the heater core, there is vacuum operated valve with a vacuum tube heading towards the heater, I dont know what this is but could it be the problem??? Im stumped Register now (free) or login to remove ads |
#3
i HAD A 1970 ELDO with the 500cid and i replaced the water pump cause when i took it off it was plugged with rust "AHHHH" so i would replace water pump and drain the block of the coolants and try flushing out your block take thermostat off and spray a high powered hose "thumb over end haha" and get what ever gunk out u can... also not well known but it works one time i have had simple green in a coolants bottle and put in radiator ran the car and flushed never seen it so clean haha and it is eco friendly so in the drain it goes
#4
Why would the water pump be at fault if the upper radiator hose is completely pressurized and hard to the touch? Wouldnt there have to be water pressure created by the pump to pressurize the hose in the first place? or is pressure from steam only... that I do not know yet. I guess a water pump is only $30 so maybe I should just replace it anyways. I like the idea about the radiator cap to SQZBOX, and that would probably help relieve pressure but I dont see how it will fix the random blockage, unless Im just not thinking outside the box
#5
just for a test i would remove the thermostat
i would also check that "new radiator" something could floating around in it |
#6
Are you using the correct Cadillac thermostat?
The reason I ask is that the big inch Cadillacs (425/472/500s) take a special thermostat. Raher than running an external bypass hose that allows water to recirculate in the block for quick warmup, the bypass passage is located in the block under the thermostat. The correct thermostat has a disc at the bottom that closes off that port once the engine is warmed up. Not having the right thermostat will cause heating problems. "..... upper radiator tube where it meets the thermostat housing......" I'm tyring to picture what you are talking abo0ut here. Could you post a picture or a better description? The valve you're talking about is simply the water control valve that controlls the amount of hot water going to the heater core and should have no effect on what you're describing. |
#8
If the top hose is swelling up it has too much pressure and the cap needs to be one of the two way recovery type. Hot coolant expands and needs to go somewhere (the coolant recovery bottle). The two way cap will allow coolant to return to the radiator after the engine cools off. I would try a new cap first as it's cheaper.
#9
So far, my thermostat was not the right kind, and the modulator for the egr valve was missing (i didnt notice because I've never had to work with one) and the vacuum lines were not hooked up right, and also the electric choke pull off was bad.. all problems that were discovered in the process. The right thermostat was that fit the block off hole perfectly was difficult to find.
On a different note I now I need the tranny shifter linkage bushings and I dont know where to find them, any ideas? |
| Thread Tools | Search this Thread |
| Similar Threads for: "1974 Eldorado coolant flow problem" | ||||
| coolant does not flow back to overflow bottle | 35benzman | Engine | 10 | 09-20-2011 01:46 AM |
| 1974 Ford Courier electric problem | Garrett J. | Electrical | 2 | 07-23-2009 07:16 AM |
| Head gasket coolant flow question | trenchdog73 | Engine | 1 | 02-16-2005 05:30 PM |
| coolant flow | jo5hi3 | Engine | 5 | 11-17-2003 08:39 AM |
| SBC coolant flow question. | M&M CUSTOM | Engine | 3 | 05-09-2003 05:28 PM |
