1974 Firebird carb help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2004, 06:08 PM
hkdonoldys's Avatar
Greetings,
I have spent most of my life around Mustangs and Ford powerplants but recently purchased a 1974 Firebird Esprit with a 350/350 set up. The ignition has been converted to a Gm electronic and the Rochester 2bbl has been replaced with a Holley 2bbl. Everything else is stock with 85k miles.
My problem is that I am only able to get 8 mpg. We had Chevy trucks thru the 70s that would get 13-15 mpg on a 350. I have checked the float level, changed the mains from 73 to 70s and and put new plugs etc.
Can I get better mpg out of this set up?
Also what about changing to a 4bbl set up and what would work best.
Thanks,
Mark in MT
Old 11-07-2004, 06:34 PM
Restore60s's Avatar
74 Bird
If you have checked everything, plugs, cap, rotor, wires, timing, even a compression test and everything checks good you may want to go to a 4bbl set-up. Does the car the way it is now blow black smoke out of the exhaust? Like running rich? If you go to a 4bbl. set up I would run something like a Edelbrock intake but I would run a factory 4bbl. Rochester Q-jet. For dependable performance on a daily driver the Q-jet is hard to beat and you don't have to adjust it every week. You should get with a automatic transmission around 14mpg. Speaking of trannys does yours shift good? Just wondering if someone might have put a shift kit in it where it winds the engine out before it shifts.
Old 11-07-2004, 06:41 PM
Restore60s's Avatar
What the heck..............? My computer keeps going crazy on this reply. Website not responding but it keeps adding it over & over.
Old 11-07-2004, 07:59 PM
hkdonoldys's Avatar
Re: 74 Bird
There is not black smoke but there is some black soot around the tail pipe, that is why I thought it was running too rich. It shifts good. There is no shift kit. Thanks for your reply.
Old 11-11-2004, 09:53 PM
hkdonoldys's Avatar
Does anyone else have any input?
