Thread Tools Search this Thread share on Facebook
  #1
Old 01-05-2012, 01:15 PM
dog_fighter dog_fighter is offline
1974 Ford 460 elecrical problem
I have a 1974 ford 460 that is out of a Lincoln and am putting it into a 1979 ford f-250. It is not currently in a veichle. The engine has good compression but I can't get any spark. I was wondering which wires you have to hook up from the coil and the distributor to a battery? I am trying to get it running before April because I want it as a pulling truck. Does anybody have any easy and cheap HP increases that you can share. My main problem is the spark right now though.
Register now (free) or login to remove ads
Old 01-18-2012, 09:20 PM
wtrueman wtrueman is offline
spark?
Maybe a shot in the dark: Do you have the "black box" system from the '74? If so, check the wiring hook up as it changed in 1975. I reversed two wires, I think one of them was purple, BUT NOT SURE, Check the different years to confirm wire shift colours, and was able to use a newer, improved, black box and my 390 ran fine. As I said, not positive but the ford black box in 1974 was like a one year wonder at least up here in Canada, Wayne.
Old 01-19-2012, 06:23 AM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
you need a hot feed to the + side of the coil. The distributor should be connected to the negative side. That should do it
Chet
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1974 Ford 460 elecrical problem"
ThreadThread StarterForumRepliesLast Post
1974 Eldorado coolant flow problemadam83Engine801-02-2012 01:20 PM
1974 ford 390FE into a opel gt what do i needcaleb1563Hotrodding Basics811-17-2010 09:55 PM
1974 Ford 400Mr.FixxitEngine1411-12-2009 07:36 AM
1974 Ford Courier electric problemGarrett J.Electrical207-23-2009 07:16 AM
1974 f-250 ford truckhonkylipsIntroduce Yourself205-13-2006 05:38 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
