1974 Mopar 440 and Trans from RV - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2008, 06:33 PM
Has anyone had any experince with how good these motors and trans are.I got an RV for free with this set-up, and I want to install it in a rat-rod project. My question is would it be worth it or should I go with a different set up. My project car is a 50 caddy...Thanks for any advice
Old 06-25-2008, 07:38 PM
Wiki Edits: 31
Unless you don't have the original Cadillac V8 I wouldn't put it in.. 1974 440 Motorhome engine has a set of funky heads and intake. same block and everything as a basic car/ truck 440 of the same vintage, but by the time you change the heads and intake, your in over $1k so free is not so free... however the engine will still bring a nice chunk of change.. clean it up and advertise it, that's what I would do
Old 06-25-2008, 07:46 PM
matt thanks for taking the time, I should have prefaced that this is a winter/winters project. I have gotten the caddy also but no engine or trans i love to trade it for a 50-55 f150 any waywhat about the trans is this any good or should i just clean em up and sell.I've been finding all this stuff on craigs list for free.again thanks for the info and if anyone has other tips as always it's appreciated
Old 06-25-2008, 08:27 PM
Wiki Edits: 31
see if you can locate a set of car/ truck 440 heads... the trans should be a TF 727 auto, which is a good trans
Old 06-25-2008, 08:54 PM
what is funky about the heads?
sam-missle
Old 06-25-2008, 10:08 PM
Wiki Edits: 31
sam-missle
they were low compression, had a water pump that fed directly into the heads.. they were industrial engines.. some were 413's, most were 440's.. on a lucky find some are standard truck engines and have normal heads, but most are not
Old 06-25-2008, 10:16 PM
thanks, all the ones i have seen were regular 413-440 engines, i have been luckey as i have purchased several over the years for the engines.
sam-missle
Mopar trans question WoodsEdge Transmission - Rearend 2 03-17-2003 06:26 AM
MOPAR 440/ H/O & 727 trans 24,000 original miles fastco Engine 1 09-14-2002 05:23 PM
