1974 nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2006, 02:41 PM
1974 nova
I have a 1974 nova it has a 400 smallblock 4 bolt main and a 350 turbo trans. i was thinking of making a 406 but a friend told me it would be weak compared to a 383 stroker and they are a piece of junk because of the steam holes and i should use it as a boat anchor
Old 09-13-2006, 02:48 PM
I got a boat, send me your anchor please.Your friend is dead wrong a 406 is usually reliable up to 550 h.p. 13.0 to 1 comp. about 7200 rpm with stock crank, 5.7 rods, good pistons and a good balance job. it is true that some crack around the steam hole but after 32 years I would say the block is ok.
Old 09-13-2006, 02:51 PM
Forgot, a well built 406 compared to simular 383 will eat it alive the larger bore further unshrouds the valves promoting better breathing with equal heads. plus cubes is still cubes.
Old 09-13-2006, 03:02 PM
nitro_baller4692's Avatar
floppers forever
a 406 is a rocket you can make alot of power,no substitute for cubic inches. maybe your friend is not a good friend and just wants your 400 for himself.
1968 Nova SS is about to end its Life Seagroves Hotrodders' Lounge 50 10-20-2009 06:04 PM
1974 nova oil pan no2nosss Engine 5 03-29-2006 06:46 AM
1974 chevy nova stevenc6137 Introduce Yourself 3 02-17-2006 04:56 PM
63 nova discs jtdchevy Suspension - Brakes - Steering 6 05-11-2004 11:35 AM
1974 Nova rebuild bblaser Engine 4 08-29-2002 10:34 PM
