1974 nova oil pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2006, 05:20 PM
1974 nova oil pan
I hope someone can help. I have a 1974 nova and a 1991-95 454.
I noticed that the nova is a rear steer will i need to buy a specel oil pan for this or will the stock pan work. Well i need a pan mine is a deep sump for a boat.
I have ben told that i need a pan like a chevy II with a notch in it.
I never built a rear steer nova BIG BLOCK please help...
Old 03-27-2006, 10:17 PM
The '68-'74 Nova has the same front suspension & steering setup as a '67-'69 Camaro, and certain models of those cars were available with big-blocks from the factory. The higher-capacity truck-type pans may interfere with the steering, but I don't think you need a notched pan like the pre-'68 Novas need. See if this one looks like it's what you need: http://www.sdpc2000.com/catalog/918/...rt-Oil-Pan.htm
The big-block versions from the factory used motor mount systems that located the engines a little farther to the right than small-blocks, and the transmission crossmembers have the mount bolt holes a little to the right, also.
Old 03-28-2006, 03:44 PM
I dont thank the 1973-74 nova is the same as a 1967-69 camaro. the subframe changed with the body in 1973. The 1968-72 nova is a frunt steer the 73-74 nova have the rear steer........In a frount steer the center steering link is in frount of the crossmember. in a rear steer the center sterring link is in the back of the crossmember .
I do like the idear of moving the engine over a little for header clearence.
Old 03-28-2006, 08:30 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
nova subframe
I have to disagree with you. the 68-74 nova has the same subframe as the 67-69 camaro. All novas of that year range are rear steer.
Old 03-28-2006, 09:22 PM
Novas didn't go front-steer until '75.
Old 03-29-2006, 06:46 AM
cool then in that case i just need a stock car oil pan for my 74 nova.
thanks for the help guys....well i ben told thay changed in 73-74. now i can get a pan and put it to gether
thanks all. no2nosss
can the wrong oil pan make this sbc leak? bigwildgrin Engine 10 12-19-2005 06:33 PM
Chev 350 Oil Pan Gasket longt Engine 0 12-16-2005 09:04 PM
Oil pan - kicked out sump good? dh79 Engine 4 06-15-2005 01:32 PM
Oil pan issue.... BoomerADF Engine 7 09-05-2004 06:39 PM
5.0 swap oil pan 5.0Falcon Engine 6 07-10-2004 05:22 PM
