1974 pontiac 400 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 07-04-2010, 08:31 AM
1974 pontiac 400
looking to build up a 74 pont 400 i have one now with 7j2 heads 650 edelbrock
looking for suggestions on what to put in it cam carb piston ect
Old 07-04-2010, 09:00 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
welcome to the site.
good for your car. post engine questions in the engine forum. some sharp folks there to help
Old 07-04-2010, 11:01 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site.
Cole
Old 07-04-2010, 11:03 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Those are pretty weak heads- they are 1972 400 2-bbl. heads w/pressed in rocker studs and no guideplates. They have the smaller 1.96" intake valves instead of the 2.11" valves. The exhaust valve is 1.77", like many heads from that era (excepting the 4X/6X and other later heads that has 2.1" x 1.66" valves).
Bottom line, a set of 6X-4 heads (Mid-'75-'77 350ci; '77-'79 W72 400ci) would be a better choice, they can be milled about 0.050" for a bit more compression if needed.
FT pistons, cam depends on many things, like what the rear gear is, weight of the car, stick or AT, how you want to use it, etc.
Id suggest some reading:
Butler- http://www.jbp-pontiac.com/
Kens- http://www.angelfire.com/fl4/pontiac...chineshop.html
Nunzi- http://www.nunzi-pontiac-expert.com/
Rock & Roll Engineering- http://pontiacpower.com/
SD Performance- http://www.sdperformance.com/
And there are magazines on Pontiac on the web:
http://www.pontiacstreetperformance.com/
http://www.highperformancepontiac.com/
There are other sites, you can do a search on google for them. The magazines have tech sections w/articles, etc.
Old 07-05-2010, 08:00 PM
thanks guys
How to make more power in a pontiac 400 psmvchaser Engine 15 05-17-2010 10:10 PM
need help pontiac 389 with 400 heads RedFox Engine 4 12-29-2007 10:41 PM
Pontiac 400, XF Code Houston54 Engine 5 11-02-2007 06:32 PM
pontiac 400 camaro guy Engine 4 04-04-2007 06:28 AM
Pontiac 400 wider than Chevy 350 Goatman01 Engine 3 01-31-2007 01:11 PM
