Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1974 pontiac 400 big block WONT start
Old 05-01-2013, 01:10 PM
Chad1965 Chad1965 is offline
Last journal entry: Jan 2012
Originally Posted by spinn View Post
Fuel in tank
12.68 volts key-on
oil in crankcase
Did you take the plugs out and verify the sparkl at the trode?
Then with a finger in the hole bump the engine and cinfirm compression? Better yet compression gauge, shrader valve in.
Then look for fuel cranking into a bucket.
Connect the carb and swab to see if the needle coming off the seat. Look for accelerator pump function and the pump shot in the primary/front carb barrel.
Cold time engine from true TDC.
Did not verify spark on electrodes, i'll try that tonight with new plugs,
and a compression test!
Ya did the timing by takin out #1 plug, saw the piston was at highest point, timing mark on balencer was at 0.. ect
Thanks for the ideas! I'll give them a try tonight.
