1974 pontiac 400 big block WONT start - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-06-2013, 11:06 PM
vinniekq2's Avatar
all the pictures floating around and we missed this car?jk.start by cleaning up everything. replace whats needed,maybe even that fuel stained carb,,,maybe visit fbird88 in ontario,he can set your timing for you
  #17 (permalink)
Old 05-07-2013, 07:55 AM
Last journal entry: Jan 2012
Originally Posted by spinn View Post
You mean advanced 15-30 to run right?
Do not get on it , until it is tuned. With the carb at a manufacturer suggested baseline get the timing set first.
No, I had the timing light on it, its 15 - 30 before 0. I wonder if someone before me did a timing chain and set it one notch off? I had the valve covers off, spun the engine over slowly and the #1 exhaust valve opens and closes a fair amount before the #1 piston reaches TDC.
  #18 (permalink)
Old 05-07-2013, 08:06 AM
vinniekq2's Avatar
as already mentioned,check for spark,check for fuel,check compression.
make sure the fuel is good quality.
clean up everything so you can work on the car.check all the top screws on the carb(for now)
When this is all done let us know what happened
  #19 (permalink)
Old 05-07-2013, 08:14 AM
Ya thats all been done, new spark plugs, fuel hose and filter, distrubutor all cleaned, spark wires all good, and I got a good holly carb on it now, I'll be takeing some new pics in a day or so.
  #20 (permalink)
Old 05-07-2013, 08:28 AM
vinniekq2's Avatar
let us know if it runs well
  #21 (permalink)
Old 05-07-2013, 01:37 PM
WDCreech's Avatar
Grumpy Old Goat Herder
15-30 before 0 would be advanced. That is about where it should be. To check the valve timing specks, you'll need a degree wheel, a piston stop, and a dial indicator.
Bill
  #22 (permalink)
Old 05-07-2013, 05:05 PM
IDK about the 74, but these old Pontiacs had nylon teeth molded over the steel on the crankshaft timing gear. The teeth would strip off or jump a tooth. Often it would happen when you try to start the engine. It would be a good idea to check that your camshaft timing is correct.
It's premature to worry what's wrong with the engine when it has such old wiring, distributor cap, dirty (and wrong) carb and so forth. Restore these to good condition first.
  #23 (permalink)
Old 05-07-2013, 10:02 PM
Okay thanks I'll check out that gear.
Ya everything else is good as I have said in previous posts.
  #24 (permalink)
Old 05-07-2013, 10:06 PM
vinniekq2's Avatar
post a new picture,lets see your workmanship?
  #25 (permalink)
Old 05-07-2013, 10:11 PM
workmanship of what? putting a fuel filter, fuel lines and new carb on the engine? im sorry I dont follow you...
  #26 (permalink)
Old 05-07-2013, 10:20 PM
vinniekq2's Avatar
re post #19,,,
  #27 (permalink)
Old 05-09-2013, 08:31 AM
Some recent pics
distrubutor cap and rotor before cleaning off contacts, Holly 750 carb, a look under the valve covers and such.
So the engine runs now, but it still needs a lot of work to get it cleaned up and tuned. That will come later the rest of the car needs alot of attention first.
I'll create a album for the car soon if anyone wants to check it out.
ID:	73869   Click image for larger version
ID:	73870   Click image for larger version
ID:	73871   Click image for larger version
ID:	73872   Click image for larger version
  #28 (permalink)
Old 05-09-2013, 05:34 PM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
The center pin in the cap doesn't look right. It appears to be recessed in the cap. It should protrude out of the cap about 3/16ths to ride on the spring of the rotor. If the spark has to jump that gap, it will affect the timing and strength of the spark at the plugs. If the cam is stock in that engine, about 4-8 degrees advanced is all they required '74 to run smoooth.
Maybe it's just an illusion from the angle of the pic, but check that. I see the pickup coil has already been replaced with a Borg Warner. That should be good.
The Following User Says Thank You to Too Many Projects For This Useful Post:
vinniekq2 (05-09-2013)
  #29 (permalink)
Old 05-09-2013, 05:39 PM
LATECH's Avatar
In picture #1 I see the center connector is not sticking down through the distributor cap as it should, causing an issue captured in picture 5....Massive carbon tracking and shorting across the rotor.
Replace the rotor with a new one and take the coil out of the cap, get the center conductor issue corrected, be sure the carbon button goes back in FIRST, then the insulator, then some dielectric grease then the coil. Be sure to use the little grounding fork on the coil frame unless it has the wire with the eyelet for the coil. I would also replace the cap in the process as well.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
  #30 (permalink)
Old 05-09-2013, 06:04 PM
vinniekq2's Avatar
a couple eagle eyes there. good observations
1974 pontiac 400 ponchopower48 Engine 119 10-31-2010 02:44 PM
1974 pontiac 400 card Engine 4 07-08-2010 05:18 PM
1974 pontiac 400 card Introduce Yourself 4 07-05-2010 08:00 PM
1974 pontiac 400 card Engine 1 07-05-2010 10:56 AM
pontiac 400 wont start rtyauch301 Engine 6 07-22-2009 02:09 AM
