Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1975 buick electra 455 engine
Old 08-23-2010, 08:21 PM
jackpetrill jackpetrill is offline
gas their was 10 gal of gas in car 10 years installed additional 15 gal car ran great should I drain all gas and flush tank..... the miss was in car before I changed plugs, wires,cap,roter sounds as if car jumped time, it bucks and lugs, turns over fast then slowes down as if battery is dead then fast again,wires are correct pulled plugs cleaned all 8 checking timing tomorrow to no#1 cylinder then pull cap to make sure its pointing to #1 thank you
