1975 buick electra455 engine
454 c10 took off valve covers had 4 bent valve rods,worked them out was a bugger I might as well take off intake manifold set aside....pulled out all valve rods took off intake gasket their were 2 lifters lying on bottom, one was apart lost retainer clip, all parts were recovered...... 4rocker arm retainers,were snapped off found those pieces also,rocker arms were off valve springs doing zip..........ordered new push rods and lifters the old lifters are flat on bottom I only have 28 thousand on moter ran fine before gum up don"t think need a cam..... drained all gas out of tank ordered carb kit if I need to start after repair will take rubber line off fuel pump that goes to tank drop hose in 5 gal can so its fresh gas........
