1975 buick electra 455 engine - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-30-2010, 07:44 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Making up your own cables is a real good idea. Not only will it cost less, but they will be better than most anything offered at the local parts store. Marine grade cables are also good- but pricey.
Get the cable terminals at the same place you get your cable, they aren't available just any-ol'-where. You might even ask if they have a hydraulic crimper w/the correct die size that you could get them to use before you solder the ends as a final coup de grāce.
Regarding terminal crimping vs. soldering (or both), THIS is just one of many discussion on the subject.
Personally, I tend to crimp then solder whenever possible. But that said, a PROPER crimp- done w/a quality tool, to the correct pressure and using good terminals, AND having the insulation stripped correctly so as to not weaken any strands- is a good connection, period- and needs nothing else except in special circumstances.
One thing that's often done, is either no tinning is done, or the wire is OVER tinned. This is where the wire wicks up the solder past the end that will be in contact w/the terminal. Any vibration or frequent movement of the wire can easily fatigue the copper, causing a premature failure.
Another problem can come w/crimping a tinned wire then re-soldering the terminal. This can actually loosen the mechanical (crimped) connection when the solder melts the second time, causing the wires to "relax" into the terminal w/less compression.
I have always crimped, then soldered. And I use shrink wrap. Not heated w/a match or cigarette lighter- but w/a hot air gun.
  #17 (permalink)
Old 08-30-2010, 08:42 AM
Originally Posted by jackpetrill
454 c10 took off valve covers had 4 bent valve rods,worked them out was a bugger I might as well take off intake manifold set aside....pulled out all valve rods took off intake gasket their were 2 lifters lying on bottom, one was apart lost retainer clip, all parts were recovered...... 4rocker arm retainers,were snapped off found those pieces also,rocker arms were off valve springs doing zip..........ordered new push rods and lifters the old lifters are flat on bottom I only have 28 thousand on moter ran fine before gum up don"t think need a cam..... drained all gas out of tank ordered carb kit if I need to start after repair will take rubber line off fuel pump that goes to tank drop hose in 5 gal can so its fresh gas........
Sorry to say, but it sounds like you had the same problem as I did with old gas. I bet the intake valves stuck in the guides and the lifter and pushrods had nowhere to go but sideways. hence, all the broken and bent parts.
If the lifters came apart and the pushrods bent then you will need a new cam. so pull out the radiator, fan, shroud, water pump, balancer, front timing chain cover.
furthermore, I would bet the valves are stuck which means the heads need to come off. you should go ahead and get a valve job while the heads are off.
I would have never guessed old gas could be so damaging to an engine if I had experienced it first hand.
  #18 (permalink)
Old 08-30-2010, 12:06 PM
Duntov's Avatar
Visit the NASCAR Hall of Fame
solvent
Marvel Mystery oil and time dissolves most varnish, or transmission fluid, either mixed with harsh lacquer thinner.
  #19 (permalink)
Old 08-30-2010, 06:59 PM
techinspector1's Avatar
Wiki Edits: 326
Excellent point, thanks for that. Keeping moisture out of the connection will go a long ways toward having a serviceable cable for a long time.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
350 crate engine zz4 in 81 buick regal Seanj Engine 1 11-02-2009 12:43 PM
73 buick 225 electra buickelectra225 Hotrodding Basics 2 09-08-2009 06:12 PM
Buick 455 and an od tranny? wellcontrol Engine 10 10-19-2002 08:19 AM
Buick 455???? stjoetalon Engine 6 08-23-2002 08:52 AM
