1975 camaro rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2013, 07:25 PM
1975 camaro rearend
What size is the ring gear in a stock RS'75 camaro rearend? Is it a 8.2 with 28 spline axles or 8.5 with 28 splines?
Thanks
Chevyguy13
Old 03-26-2013, 07:32 PM
big gear head's Avatar
High Performance Rear Ends
Starting in '71 and running through '81 all Camaros and Firebirds got the 8.5 corporate 10 bolt with 28 spline axles.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (03-26-2013)
Old 03-26-2013, 07:43 PM
Thank you for the quick response. Getting ready to do a gear swap and needed to know what to order. Thanks!
Big jump when i shift "d" (1975 Camaro) Calderone Transmission - Rearend 2 03-28-2008 04:30 PM
1975 z28 Camaro Clone Project 52Ford Body - Exterior 1 07-18-2006 03:22 PM
72 camaro rearend 72 Z28 Transmission - Rearend 2 11-26-2003 12:21 AM
69 Camaro rearend Bowtie1034 Transmission - Rearend 0 11-02-2002 02:52 PM
WHich rearend would be better for 85 camaro? stonedchihuahua Transmission - Rearend 1 10-29-2002 04:56 PM
