1975 Corvette; Clutch or Tranny issue
Hi Guys, I have a 1975 Corvette with 4-speed Borg Warner Super T-10 Trans
Issue When I drive for a while (say about 30min or so ) when I stop at a light I can hear a noise from the car when I push in the clutch it seems to continue only a slightly different sound and even when I put in neutral and let off the clutch Sounds like the tranny isn't disengaging completely (With clutch pushed or in neutral with clutch disengaged). Sounds like its scrapping like the surfaces are touching on each revolution when they shouldn't be (Like in Neutral or clutch disengaged) Any help would be greatly appreciated THANKS!!! |
Sounds like your throw out bearing may be going
Artificial Intelligence is no match for Natural Stupidity Chet |
Thanks!!!
Thanks Chet for the quick reply
I greatly appreciate your input |
Usually when a TOB is going you will hear the rumbling kind of noise when the clutch is depressed just enough for the TOB to contact the pressure plate. When the clutch pedal is all the way out, there should be no contact between the TOB and the PP- unless the linkage is out of adjustment and/or the entire clutch assembly is worn. If adjusting the clutch doesn't help it's probably time for a clutch, etc. If that's the case, don't neglect to have the flywheel turned. A new clutch can still slip if it's not turned.
Another thing you should check is the pilot bearing in the back of the crankshaft. It's what the tranny input rides on. |
Thanks!!
Thanks for your help!!!
I am suppose to have a rebuilt tranny with new clutch etc.. but I am not so sure he looked at everything. Thanks again for the help |
Will do
It only seems to do it after about 30 to 45min of driving The noise will start (Or that is when I notice the noise) when I stop at a light and seems like the more I use the clutch and change gears but of course that may only be my thinking |
Hate to hijack, but why dont you like the roller bearing pilot? THey are the only thing that I have found to work in racing apps. I have seen some fall apart on high mileage street cars, though. |
Heres the Auto Gear company answer:
Aftermarket needlebearings can be cheap. Not necessarily a problem, however as you alluded to, they can fall apart in high mileage situations. Also, the NB doesn't like ANY misalignment. Bellhousing alignment is critical for their long term survival. Several of our customers had their inputs torn up by an improperly installed NB. The needles were trying to skew, stopped rolling and started sliding. For a home mechanic, installing a bronze bushing is easier, one less thing to worry about. If the drivetrain alignment isnt spot on, the bushing will accept some misalignment. A lot of the off the shelf bushings have too much iron in the sintered bronze. The large amount of iron can score the input, weld itself to the input and then tear up the crank, or weld itself to the input AND the crank. Hence the magnet check. We use genuine self lubricating Oilite bronze. But, some of our customers don't want to ship an $8 bushing across the country, so I usually have them look for the more expensive 'HD' or 'Premium' pilot bushing at the parts store, and check with the mag. This of course doesn't apply for OEM ballbearing applications. |
never make the mistake of assuming new is good !!!!
A short page on pilot bearings is here.
| 1975 Corvette Brake Problem | Tick | Suspension - Brakes - Steering | 2 | 02-03-2012 03:08 PM |
| Unusual Clutch Issue | Argess | Transmission - Rearend | 4 | 08-19-2011 04:25 PM |
| 1975 corvette | jimbob58 | Engine | 2 | 03-13-2010 07:43 AM |
| Clutch Issue | Argess | Transmission - Rearend | 4 | 09-07-2008 08:54 AM |
| 91 corvette issue | dikbutkis | Electrical | 1 | 06-14-2007 05:38 PM |
