-   -   1975 ford 300 inline six, manual trans that fit? (http://www.hotrodders.com/forum/1975-ford-300-inline-six-manual-trans-fit-221717.html)
Chris Kemp 07-15-2012 10:22 AM
Ok this should be a quick one for all the Ford transmission Gurus that are on here. I have a 75 ford 300 inline six with the stock cast iron bell housing and stock three speed manual transmission that came with it. I am putting the engine in a T-bucket and I am not sure if I am going to use the three speed. I would like to know what other manual transmissions would bolt up to this engine. Is there any over drives available and will any of the 90's mustang 5 speeds work.
Thank you very much!
Chris
OneMoreTime 07-15-2012 11:14 AM
In the mid 70's Ford made a toploader 4 spd with overdrive which came in vans and pickups that could be very suitable and is not very spendy..most older ford trans shared a bolt pattern and input spline so are very interchangeable..
Sam
Chris Kemp 07-16-2012 08:59 AM
Sam
Really appreciate the info Sam. Can't understand why more people haven't posted. I was hoping for more choices, maybe I worded the question wrong.
big gear head 07-16-2012 09:53 AM
I saw this on craigslist today. It might be worth checking out. 2006 mustang transmission 5 speed I think they have the same 10 spline input shaft as the older transmissions, but I'm not sure.
AutoGear 07-16-2012 12:18 PM
WATCH THE INPUT SHAFT LENGTH.
Some time around 2000; the length of the input increased on the Ford T5's
It probably has something like a 3.35:1 1st gear; so don't go crazy with the axle ratio's. 3.23 or 3.31 is all you really need in your little buggit
