1975 ford 300 inline six, manual trans that fit? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2012, 10:22 AM
Ok this should be a quick one for all the Ford transmission Gurus that are on here. I have a 75 ford 300 inline six with the stock cast iron bell housing and stock three speed manual transmission that came with it. I am putting the engine in a T-bucket and I am not sure if I am going to use the three speed. I would like to know what other manual transmissions would bolt up to this engine. Is there any over drives available and will any of the 90's mustang 5 speeds work.
Thank you very much!
Chris
Old 07-15-2012, 11:14 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
In the mid 70's Ford made a toploader 4 spd with overdrive which came in vans and pickups that could be very suitable and is not very spendy..most older ford trans shared a bolt pattern and input spline so are very interchangeable..
Sam
Old 07-16-2012, 08:59 AM
Sam
Really appreciate the info Sam. Can't understand why more people haven't posted. I was hoping for more choices, maybe I worded the question wrong.
Old 07-16-2012, 09:53 AM
big gear head's Avatar
High Performance Rear Ends
I saw this on craigslist today. It might be worth checking out. 2006 mustang transmission 5 speed I think they have the same 10 spline input shaft as the older transmissions, but I'm not sure.
Old 07-16-2012, 12:18 PM
WATCH THE INPUT SHAFT LENGTH.
Some time around 2000; the length of the input increased on the Ford T5's
It probably has something like a 3.35:1 1st gear; so don't go crazy with the axle ratio's. 3.23 or 3.31 is all you really need in your little buggit
ford, manual transmission
Need info on a 300 inline 6 Ford bowtieorbust Hotrodding Basics 37 06-09-2011 12:33 AM
Ford Inline 6 300 ( most miles ? ) crystalbluevib Engine 4 03-02-2010 01:37 PM
300 ford inline 6 going into Triumph TR4 ivonius Introduce Yourself 2 01-14-2009 08:50 PM
300 inline six ford steve stearsman Engine 5 12-23-2008 02:47 PM
1983 ford inline 300 robmccolery Engine 4 02-04-2007 05:36 AM
