1975 nova 8.5 rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2012, 05:22 AM
Does anyone know what donor car at pick a part can I grab a 373 ring and pinion out of to put in my 1975 chevy nova 8.5 rear end. should I grab the carrier and all or just take the ring and pinion gear off?
Old 02-19-2012, 07:41 AM
BOBCRMAN@aol.com's Avatar
I doubt that you will find a 3:73 geared rear in the boneyard. If by some miracle you do. Get the carrier also. Most mid seventies had 2 series carriers.
Old 02-19-2012, 07:46 AM
Last journal entry: update
Plenty of 3.73:1 gears if you know what they came in. Most '71-'74 Z/28s, '77.5-'79 Z28s with 4-speed, many 4x4 '80-'up 1/2-ton full-size V8 pickups, some 2WD 6-cylinder '80-up half-ton full-size pickups.
However, I'd rather spend $144 on these: http://www.summitracing.com/search/?...M-741001&dds=1
Old 02-19-2012, 11:11 AM
Lots of later model Chev 4x4 trucks had 3.73 gears. They use 30 spline difs after 89 so that wont work for you. You have to have a diff for a 2.73 and numerically higher ratio to use a normal GM gear set, so if you have a 2.56 or 2.42, it wont work.
Most driveline shops keep old gear sets and have some 3.73 on the shelf.
Old 02-19-2012, 04:17 PM
Like I said. Good luck finding pre-80's Z/28's etc in the bone yard. Around SE Michigan you won't find anything older than mid eighties, if that.. Truck units won't work.
Old 02-19-2012, 07:06 PM
Truck 8.5 gears are fully interchangeable with car 8.5 gears. Of course they will work. I put the 3.42:1 8.5" gears from my old '83 C-10 into my landlord's '81 Firebird. Even used the C-10 3-series open diff. ( carrier ), since the 'bird was 2.41:1, ( 2-series ) and Scott doesn't need a posi. Both are 28-spline, so I kept the 'bird's original axleshafts.
You're probably thinking of how the truck 12-bolts used an under-size pinion shaft compared to the car 12-bolt.
Old 02-21-2012, 03:57 AM
1975 nova rear end
Thanks everybody! I ended up pulling a 342 rear end from a 1989 full size pick up truck for 60 bucks with carrier and all from pick a part in wilmington, CA. its one legged but thats cool for me im not racing!
1975 Trans Am 4 link rear end Ginger_ninja Suspension - Brakes - Steering 2 02-13-2011 02:30 PM
Reed 327 nova 1975 nova327 Introduce Yourself 4 10-30-2009 01:44 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
1975 nova LN for sale rockslide Hotrodders' Lounge 1 01-12-2003 09:07 AM
1975 Chevy Nova SS pinstriping kalong12 Body - Exterior 3 11-04-2002 02:28 PM
