1975 trans am 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2006, 07:33 PM
william27103's Avatar
1975 trans am 400
is the 400 engine in a 75 trans am a pontiac, buick, olds, or chevy engine
thanks,
will
Old 02-08-2006, 08:04 PM
its a pontiac engine.
Old 02-08-2006, 08:49 PM
ok, i also have a 79 ta that's a work in progress with what i believe to be the original motor, which one is it
Old 02-08-2006, 10:20 PM
In the 1979 TA that is a real Pontiac 400 motor.. the last 'real' Pontiac motor made as far as I'm concerned. They started using Oldsmobile 400 motors in some units due to it meeting emissions easier.. (GM didn't bother to tell and got into hot water when the cars were brought in for servicing and the Pontiac mechanics found themselves staring at an Olds motor! it was a screwed-up time!
Old 02-08-2006, 10:57 PM
In 75 unless someone has changed the engine it's Pontiac. As far as the 79 goes it could be an Olds engine as about the only T/A's that were equipped with the Pontiac engine around that time period had 4 speed transmissions, automatics had the 403 Olds. Willian 27103 if you could would it be possible to send me some pics either private message on here or to my e-mail? I could give you a definite answer as to what you have. Goat
Old 02-08-2006, 11:39 PM
If there's a hose or tube between the front of the intake and the water pump, it's probably an Olds. If the intake meets the pump with only an O-ring in between, it's a Pontiac.
Old 02-09-2006, 11:55 AM
i'll check and see, sorry i can't get any pics, my camera is broken
Old 02-09-2006, 01:37 PM
One other way to determine if it is the Olds engine is if the oil fill is a tube at the front of the block at the intake.
why is my 400 trans shooting the fluid back through the filler tube 403pontiac Transmission - Rearend 5 10-31-2006 10:39 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 01:48 PM
TH 400 Speedo Gears rs67ss Transmission - Rearend 5 04-04-2005 12:58 AM
stay 400 or go 455 Jared Engine 9 07-06-2003 04:26 AM
chevy 400 buildup 406chevelle Engine 15 06-08-2003 04:41 PM
