1976 built Pontiac 455 pinging! - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 03-13-2013, 11:42 PM
Niko
in the 9:1 +. a ball park number is good for me thank you
so im guessing pining is not a detonating issue, 91 octane should be just fine right? its a timing or air to fuel mixture problem?
  #32 (permalink)
Old 03-14-2013, 03:44 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Could be timing, f/a ratio, or even a hot spot in the chamber(s). Again- be sure there's no vacuum leaks.
Look at the plugs to see if they're the right heat range and at the plug color to see if they look lean.
Get the carb secondaries working. Using the vacuum reading at idle, see if the power valve is correct. Again- if the carb had been used previously then allowed to sit dry, the PV needs replacing.
Map the timing curve and see what the initial and total is, and at what rpm the total is all in by. See how much the vacuum advance is adding. Note whether the vacuum advance is connected to manifold or ported vacuum.
See that the mechanical advance and vacuum advance mechanisms are working freely and not hanging up.
If you don't have a dial back timing light you can make a temporary timing tape (or buy one), in order to use a regular timing light to see where the advance is at various rpm. Post #8 has a link to info on timing.
After you are sure the total timing is not excessive, take it out and see if it's still pinging. If it is, it's time to look closer at the fuel/air delivery. Or the possibility the heads were milled excessively, or that you may have domed pistons.
  #33 (permalink)
Old 03-14-2013, 11:30 AM
LATECH's Avatar
20 degrees initial timing sounds to much.A total of 27 sounds like the dizzy aint working right either.
Fact is stranger than Fiction
  #34 (permalink)
Old 03-14-2013, 12:41 PM
something's not adding up... with the little advance on the distributor to the secondaries not opening, are you sure you don't have a nasty vacuum leak somewhere?
  #35 (permalink)
Old 03-14-2013, 11:14 PM
Niko
I just pulled the tranny out today being rebuilt tomorrow it should be back in, i am going to pull all of the plugs, order the kit and diaphragm for the carb/secondaries, also a power valve a higher rating i suppose like someone said on here. then in about a week when i get paid im going to get a new distributor so theres not advancing problems. see how that works out hopefully it fixes the issue.. when i drove it today i payed close attention to when it started to ping, if im rolling or at cruising speed and floor it it will ping in the mid range and stop pining at higher range.. so maybe it is the power valve? because its not giving it the fuel when it needs it
  #36 (permalink)
Old 03-14-2013, 11:45 PM
Niko
Also do you think the cam needs to be degreed ? is it even large enough?
  #37 (permalink)
Old 03-15-2013, 01:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The power valve being old or rated too high could lean it out under load. I recommend getting the timing sorted out, install a power valve in the 55 to 65 range and then see what you have. There's no way to say if the cam is what you want or not at this point.
Regarding the PV- the one you have is supposedly a 35. That means that it will not enrichen the A/F mixture under a load until the manifold vacuum drops all the way to 3.5 in/Hg. Under "normal" circumstances, a PV rated around 65 is recommended- but the exact PV rating is dependent on the engine vacuum in gear at idle. The bigger the cam, the smaller the PV rating (all else being equal). This is because an engine w/a bigger cam idles w/less vacuum than a smaller cam. If the PV rating is too high, the PV will open at idle, causing idle quality issues.
So:
  1. Sort out the timing
  2. Change the PV
  3. Install the secondary diaphragm- if it's torn, there will be a vacuum leak, however the size of the orifices involved will not flow enough air to be a big vacuum leak- but it's a leak, nonetheless
  4. Check the plugs for heat range and color
  5. Check for vacuum leaks
Nothing wrong w/doing a compression test in the meantime. It can give some idea of what the compression is, although it's not anywhere near as accurate as actually measuring things.
As far as the camshaft phasing, this can be looked into further if the above still hasn't rectified things.
  #38 (permalink)
Old 03-15-2013, 10:53 PM
Niko
okay that makes perfect sense, thank you for explaining i really appreciate it. i think once i get the lower rating power valve i wont be leaning out becase how you explain it sounds like what its doing then once the timing is worked out i should be good. what do you think timing wise? 12 inital and 30 total?
  #39 (permalink)
Old 03-16-2013, 06:42 AM
Bonneville462's Avatar
Try 10 initial, 20 mechanical all in by 3000 rpm, disconnect the vacuum advance until you have everything sorted out...
Find 0 degrees top dead center on the damper, measure 2" clockwise from that and make a mark. That will be 30 degrees give or take a few.. You'll see it all come together when you rev the motor with the timing light on the damper...
Did you check the power brake booster, is it leaking? Can it hold vacuum for at least a day or two?
  #40 (permalink)
Old 03-17-2013, 01:39 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The above should read "If the PV rating is too LOW, the PV will open at idle, causing idle quality issues."
But I think you understood the gist of it- you want a PV that will open when the engine is under a load, but NOT open at idle or light throttle cruise conditions.
From Holley Performance Products Frequently Asked Questions
QUESTION: How do I tell what size power valve I need?
ANSWER: To properly size a power valve, take a vacuum reading at idle and if it is above 12" for a standard transmission a 6.5" will be safe to use. For automatic transmissions take a vacuum reading in gear at idle (w/engine FULLY warmed up) and if the vacuum is below 12" divide that in half for proper size. Example 9" of vacuum in gear at idle will require a 4.5" power valve.There is a video on this procedure on Holley TV.
Holley video explaining it: Holley Carburetor Power Valve | Holley TV
  #41 (permalink)
Old 03-20-2013, 10:12 PM
Niko
oh okay that helps alot! never knew that im really hoping this fixes my problem and timing aswell ive been super busy for a few days thats why i havent been to active in this feed but im back now @cobalt
455, 6x head, horse power, hot rod, performance, pontiac, torque
1976 Trans Am 455 jeffysit455 Hotrodding Basics 2 11-23-2011 07:28 PM
1976 L48 built up, looking for hp guesses MrDedham Hotrodding Basics 0 09-27-2011 02:44 PM
buick 455 and pontiac 455 valve covers rooster88 Engine 2 07-14-2011 07:50 PM
what carbs will work with a 1976 oldsmobile 455 wastedracing Engine 7 03-16-2007 08:36 PM
1976 pontiac trans am zipfactor General Rodding Tech 9 08-07-2003 04:12 AM
