1976 chevy 350 rochester 4Bbl jetting problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2012, 01:52 PM
Hi, I am getting frustrated with my Monte Carlo Rochester jetting problem. It is a 1976 and I have changed it from 2 Bbl to 4Bbl. The metering rods were messed in it and the jets were missing. I had other jets lying around and so I installed them but the car bogs like crazy while in primaries and majorly in the secondaries. I pull out of the driveway and the car hesitates at about half thorottle but if you are really easy on it then it is okay. Dont even think about flooring it. I was wondering what is a good combination for Primary metering rods, Primary metering jets and secondary metering rods. It has a stock cam, shaved heads (0.060") and no egr valve. It starts like a dream but driving it makes me think it is more gutless than a 16 hp engine. I know that the mixture is too lean because if you pump the gas while you drive the engine runs a lot better. The secondaries have been set correctly with the spring pressure and i think that the secondary metering rods are ok but i still want to know what you have that works like a dream. Thanks for taking the time to read this.
Old 03-23-2012, 01:23 PM
bigdog7373's Avatar
Of course it's fast
Fuel pressure ok?
electrical problem 1976 mustang 2 hemi joe Electrical 4 03-19-2010 07:02 PM
Holly 4bbl carb help. or timing problem Frequency21 Engine 4 06-04-2009 11:27 PM
stock '77 2bbl rochester, to edelbrock 4bbl, bracket ? fast68 Engine 2 03-19-2009 06:42 AM
Ford fe holley 4bbl carb problem 62galaxiguy Engine 1 04-01-2007 05:54 PM
I think I may have a problem, (400/4BBL) ramjet Engine 2 03-09-2003 07:02 PM
