1976 chevy C10 where to buy a rearend or what kind? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2008, 09:14 PM
I am rebuilding a 76 chevy pk c10 i want to put like a 12 bolt posi trac unit in it with 4.10 gears. I am putting a 388 stroker in the truck that will be putting out 500hp and nearly 520 ftlbs of tq. i dont know where to buy a rearend i would like to get a rebuilt one to save on money but i know that might not be possible. what would be best?
Old 09-25-2008, 11:04 PM
j.d.brown.042964's Avatar
406 Caprice:Rust Never Sleeps!
If you go to the Knowledge Base and type in truck 12 bolt as a search, you can get alot of info and possible leads from there. -Jim
Old 09-26-2008, 04:13 AM
If you are running that much H.P i would use a ford 9in and have redrilled to a chevy bolt pattern
Old 09-26-2008, 05:41 AM
The Chevy truck 14 bolt FF with 4.10 ratio was a very common rearend on 73-87 C20 and K20 trucks. There are hundreds of them in the junkyard, and the rear disc brake conversion is available from several sources (stock drums are huge and very heavy). If you buy the driveshaft at the same time, it should just bolt directly in to your truck.
The big disadvantage of the 14 bolt FF is that it uses 8 bolt wheels, so it won't match your front end. Also, the limited slip in this axle is a GM/Eaton GovLoc, which is probably not the best choice for your application. It can be replaced with a new Eaton Positraction unit, but the prices are steep. The big advantage is that since its a full floating axle, if your new engine does happen to break an axle (not very likely with this unit), your wheels will stay on the truck.
Bruce
Old 09-26-2008, 10:54 AM
prostreet6t9's Avatar
Differential/Driveline
You can usually rebuild yours for a little less than just buying one already done,or at least you will know you have all new parts and not someone else's mess.You can always buy all the parts and take the diff to a shop and have them set it up, if your not comfortable doing it. all new, you should be able to get it all done for 950 parts and labor.
Posi part # 19556-1,"assuming you have a 12 bolt", shop around and see what you can get one for.
Old 09-26-2008, 01:57 PM
OHD's Avatar
OHD OHD is offline
google DANA 60
Old 09-26-2008, 03:34 PM
Originally Posted by OHD
google DANA 60
Now there is a dodge guy for ya!
Actually, there was a dana 60 used in the early chevy 3/4 ton truck, it has ford 9" style axle brg's,and housing end's. I believe it was a coil spring truck, so a little more brackets to cut off,But I think the width is correct.Might be a pretty good choice if he can find one.
Old 09-26-2008, 03:47 PM
Correction! it was used in the 69 to 72 1/2 ton.
Old 09-26-2008, 04:24 PM
SSedan64's Avatar
Some Mid 70's Chevys had the Dana 60 also. I looked at a Big 10 model pickup, Long bed had 454, 400trans, & Dana 60. Think it was a 74 or 75, been so long ago I can't remember. It was a leaf spring suspension tho'.
Old 09-27-2008, 09:15 PM
Q-4000's Avatar
Last journal entry: my new rat rod project
you could do this for about 2400 for a 14 bolt the 9" ford is cheeper and the DANA 60 is prob. your best option tons of aftermarket support for them!
http://www.drivetrain.com/4x4.html
Old 10-07-2008, 01:45 AM
fast68's Avatar
likes chevy trucks & boobies
gonna cost you lotsa bucks unless you can find an original dana 60rear that is 5 or 6 lug and not a common 8 lug full floater like they were in the 72 and older trucks
these were pow-r-lok unit rear
very good units these olkd dana 60s had in them in the gm trucks
some were coil rear and most were leaf rear
the 6 lug ones were semi float like the 10and 12 bolt 1/2 ton axles and were found in some of the big block engine optioned trucks
396 and 402
all the 8 lug ones were full float and lots heavier and were commmonly taller ratio 4.10 and less
i have owned a few dana 60 72 older trucks over the years
the last one was a powerlok 4.10 ratio and leaf rear
the semi float ones tended to be coil rear(1/2 ton big block)
no factory big blocks in the trucks until 1968
do google searching
contact wes on 67-72chevytrucks.com
search search search online
a dana 60 or a 9" from an old ford truck will be the good strong and cheap route
ikf you have an old arc welder laying around then youll be good to go
if you find a dana 60 from a 63-72 chevy leaf rear pickup that is not 4x4 then the spring perches will bolt same to your later leafs if you use the 72 older hardware though
same leaf springs
56" length almost always
full floaters can be converted to semi float but you need donor parts regardless, from a semi floater
so.,..
you need to already have planned what you want exactly
can you weld or will you weld ?
how much skill/experience do you have to do any of this ?
how much knowledge of what rear were used in what years makes model and what posi or locking diff units were used and availablein each year and model of axle fora given vehicle year make and model ?
these old dana 60s had really super nice locking diffs in them
i mean DAMN nice
strong
reliable
real
not gov lok grenade lok trash in the later 70s years and 80s and 90s
'66 Chevy rearend swap 66Chevy Man Transmission - Rearend 1 10-05-2007 09:00 AM
Want to change rearend gears in 57 Chevy... HELP!!! Drew's 57 Transmission - Rearend 7 02-21-2006 11:05 PM
chevy truck rearend swap OldSkooLNewbie Transmission - Rearend 0 01-18-2006 09:07 PM
what kind of power tools do you buy??? mustangman1968 Garage - Tools 0 04-14-2004 01:58 PM
Need rearend for '55 Chevy p/u? amphib Transmission - Rearend 1 01-12-2002 06:11 PM
