Thread Tools Search this Thread share on Facebook
  #16
Old 12-16-2008, 12:20 PM
sixty9santa sixty9santa is offline
Does anyone know if these nitrophyl floats (Motorcraft CM-1062-A/Ford D4AZ-9550-A) will work in a 4100?
I know that they are listed to work in the 2100, but not sure is these floats are the same for both primary and secondary?
Appreciate any and all help,
Chris
Register now (free) or login to remove ads
Old 05-23-2009, 12:44 PM
nicky53 nicky53 is offline
Update?
I like that you're doing something with a Granada. Let us know how things are going with it. There is a project car like yours on http://www.StreetClubTV.com you should check it out. I think you'd like it.
-Nic
Old 05-23-2009, 01:02 PM
FEDDO's Avatar
FEDDO FEDDO is offline
Car looks great. you will never regret using the 4100 carb,either the 1.08, or the 1.12. think port velocity. i would put in a set of flat tops and a set of 69-71 ,351 windsor heads cut .060 and run the car. makes for a nice combo.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1976 Ford 302 Build Q's"
ThreadThread StarterForumRepliesLast Post
FORD 302 vice FORD 302 HipoKauai HawaiiEngine611-09-2008 01:27 AM
460 ford buildJaredEngine1009-03-2008 10:54 PM
Wanna Talk Cars "Fords"66FalconHotrodders' Lounge1710-01-2005 05:29 AM
302 Ford Small Block IdentificationDreanEngine608-08-2005 01:19 AM
Heads for Ford 302Coleman396Engine1203-31-2004 08:51 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
