1977 3/4 rear brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2005, 09:54 PM
Working on 1977 3/4 ton extended cab f250 with 460cid and C6 tranny. Doing rear brakes and seem to extra springs in "spring kit. Can some one send me a picture of the Bendix brake shoe and spring layout. I think that there were some broken springs when it fell apart as I disassembled. Could be that the kit just has extra part or is for multi brake sets. Dumb me I don;t have a shop manual for this vehical as though my 65 year old mind had seen these before. My email is posted on this site in my profile.
al
Old 12-17-2005, 10:08 PM
poncho62's Avatar
Wiki Edits: 5
Don't know about the spring kit, or the setup, but....I always do brakes one side at a time, so you have something to refer to, if you forgetn how it goes. Saves grief............
Ontario Rodders
Old 12-17-2005, 11:03 PM
abstruse dutch uncle
Here is one listed for a 1.25ton, looks identical to my 1ton. If your 3/4 is full floating, with the hook type retainer pins, it should be the same. If not, I'll find you a different pic.
#14 are the retaining springs, and #12 are the pins.
Old 12-18-2005, 11:58 AM
Got answer
Thanks to all that replied. I got pic I needed.
Brakes yogo2121 Hotrodding Basics 7 12-06-2005 07:02 AM
1970 chevy rear disc brakes scottsspeedshop Introduce Yourself 1 07-07-2005 11:02 PM
Rear end identification help 71gtx Transmission - Rearend 1 11-07-2003 07:14 PM
rear disc brakes BIGBLOCKSTANG Suspension - Brakes - Steering 3 02-11-2003 10:14 AM
converting GM 10 bolt to rear disc brakes, have questions HotRodF100 Suspension - Brakes - Steering 7 09-18-2002 11:22 AM
