1977 Camaro - heater fan runs when key is on? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2005, 10:53 PM
dpjmw's Avatar
Question 1977 Camaro - heater fan runs when key is on?
1977 Camaro. Even when the heater and a/c switch is in the off position, when I turn the key on, I hear the slight hum of the heater fan blowing. What should I check? Thanks in advance.
Old 01-03-2005, 05:56 AM
poncho62's Avatar
Wiki Edits: 5
thats normal in those years..................it goes off when you slide all the controls to off.
Old 01-03-2005, 10:51 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Yep it's normal, part of the fresh air ventilation system.
Troy
Old 01-03-2005, 04:57 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
In the summer if it annoys you unplug it and cover the lead to power.You do not want to have to change that blower motor .They are a pain,I have never ran into one as bad as a 2nd gen F-body.
Old 01-04-2005, 08:19 PM
Canzus's Avatar
a red wool sock on his dinger
You've never done a Taurus, have you??
SteveL
Old 01-05-2005, 04:42 AM
RCastle's Avatar
No I haven't,Iown one now,an SHO.Had a 95 also.On the 2nd gen Camaros the inner fender has to come out,it is a pain.Also an S-10 is a pain to swap a heater core.
Old 01-05-2005, 06:37 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
fan annoyance
The high speed setting delivers all the power to the fan. I cut into that wire and installed an inline fuse. When I want the fan off, I just remove the fuse and set the fan on high.
Old 01-10-2005, 04:33 AM
willowbilly3's Avatar
Last journal entry: Body mods
Don't you just take the bolts out of the inner fender and pry it down far enough to reach the Motor?
We always unplugged the connecter from the blower motor reistor and bent the low speed tab over then plugged it back in. Those systems were a pain in the rear during moderate weather when you didn't need the heater but constantly had to fiddle with the heat control to keep it comfortable.
Old 01-10-2005, 11:13 AM
bullheimer's Avatar
NEVER use credit cards!
i learned something new too. why not move the temp switch over to half way then it wont be too hot for you.
Old 01-10-2005, 12:22 PM
RCastle's Avatar
Maybe you can,I do not because ,if it can happen to someone it will happen to me.I know I would bend the fender and then have to yank it out anyway and straighten it out.I f it was plastic,it would be ok.But I have only seen metal and that **** is thick.
Old 01-10-2005, 12:41 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
hell chevy has been putting the fan behind the wheelwell for yrs. on my 63-4-5-6-7-8 chevy's all i did it & when i had to change it, i cut a hole bigg enuff in the inner wheelwell to get it out. then i made a new panel to screw & sealed back in place....joe
Old 01-10-2005, 01:24 PM
RCastle's Avatar
That is a pretty good idea.No one would see it and if it was painted to match it will blend right in.Chalk that up as another,"Why did'nt I think of that?".The Malibu is easy as pie,open hood,remove blower.
